Chain lube for street and a little offroad - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By Webfors
  • 2 Post By PerazziMx14
  • 1 Post By Hatchi
post #1 of 10 Old 05-05-2019, 09:37 AM Thread Starter
I have been googleing a bit, and I think I will go for Motul spray. But which one. They have at least C2, C2+, C3 and C4
Some are for sports bikes, some for offroad, but can't I just use an allrounder?
Are the interchangeable? I remember on my ordinary bike that I need to remove old one if I put on wax
Regards, Lars.
bonne is offline
post #2 of 10 Old 05-05-2019, 11:32 AM
Webfors's Avatar
Dupont's Chain Saver formula would be a good candidate. Incredible creeper oil and dries into a dry wax without any mess or accumulation.
I use Wurth HHS2000, but it is tacky and will attract dirt/dust.
Spec likes this.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #3 of 10 Old 05-05-2019, 01:39 PM
Stalky Tracker's Avatar
You could check out WebBikeWorld and all their chain lube reviews and comparisons :
https://www.webbikeworld.com/chain-lube-reviews/
I am using Tirox Synthetic Chain Wax now that my supply of original recipe DuPont Multi-Use Dry, Wax Chain Lube is all gone.
YMMV
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 10 Old 05-06-2019, 04:32 PM Thread Starter
But how about the Motul? And can any lube be added onto any existing already on the chain? (Do I need to remove the existing first?)
Regards, Lars.
bonne is offline
post #5 of 10 Old 05-06-2019, 04:52 PM
Ask 10 riders about 10 chain lube options and you'll probably get well over 100 opinions.
I've used what I think was the C2 stuff in the past. Thought it worked fine. A little sticky, perhaps. C4 is intended for racing chains, it says. No experience with it.
I have used their chain paste, and didn't think much of it. Had my shortest-lived chain ever using that stuff. As a paste, obviously it doesn't penetrate anything, anywhere.
V-Strom Ry 2 is offline
post #6 of 10 Old 05-06-2019, 05:03 PM
jerryscove's Avatar
Check out Ryan at Fortnine (youtube) on Lubes
Never Buy Chain Lube Again? Comparison Test
Ryan not only performs 4 different tests to see what lube works best for chains with O rings but he also explains chain mechanics and friction. What is chain lube for? Manufacturers say "rust prevention". Find out what mfgs recommend.
jerryscove is offline
post #7 of 10 Old 05-06-2019, 05:11 PM
PerazziMx14's Avatar
Buy a Scott Oiler and a $3 quart of ATF and you'll have enough chain lube for 30,000 miles. You can also expect double+ mileage out of chain and sprockets. All the while never needing to manually cleaning you chain again. The Scott continuous oiling will clean and lube the chain as you ride.
The $143 dollar investment up front pays for itself in short order.
OydnaR and branthopolis like this.
PerazziMx14 is online now
post #8 of 10 Old 05-06-2019, 10:58 PM
Ryan's results. Oil wins.
branthopolis likes this.
Hatchi is offline
post #9 of 10 Old 05-07-2019, 12:08 PM
Ryan's tests exactly coincide with my personal experience with Belray Superclean. While it was nice having a nice and clean backside, i noticed small bits of rust appearing after only slight wetness (if you donnt reapply often). I was also not impressed with the rollers lubrication. That brought me to the Tutoro oiler. But as i have found out, there are tradeoffs, and no free lunch. Messier usually oils well, and vice versa.
2016 DL1000 ABS
ERockJL is offline
post #10 of 10 Old 05-07-2019, 12:17 PM
Big Boy's Avatar
You may want to investigate ACF50. https://learchem.com/products/acf-50.html
W. C. Fields
Big Boy is online now
Chain Lube Comparison Video from FortNine CanadianStrommer Canadian Troopers 12 04-23-2019 05:11 PM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 04:11 PM
Moto Pro Chain Lube Illinois General V-Strom Discussion 13 07-31-2013 11:13 AM
Lucas Chain Lube - Aerosol Spray Can Prime General V-Strom Discussion 8 07-07-2013 04:00 PM
A (Personal) Caution on Using Dupont Teflon Chain Lube, (Some Pics) Black Lab General V-Strom Discussion 73 11-26-2009 03:03 PM
