Wear on chain outer plate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 4 Post By blaustrom
  • 1 Post By locoblanco
  • 1 Post By Brockie
  • 1 Post By one_six_right
post #1 of 6 Old 04-27-2019, 12:13 AM Thread Starter
I was out riding today when one of the screws holding the chain guard came loose. This caused the metal plate on the inside of the guard to rub against the chain whenever I hit a bump in the road. There is some wear on the edge of the outer plate of the chain. Does the chain need to be replaced? Maybe I'm just being paranoid but I'm about to go on a long trip and I really don't want to break a chain halfway.
Picture attached for reference. A little bit of bare metal can be seen on the bottom of the outer plate. Looking at it from the edge it doesn't look like its reduced the thickness of the plate much. Bikes a 2018 DL650XT.
one_six_right is offline
post #2 of 6 Old 04-27-2019, 01:12 AM
blaustrom's Avatar
It does not look like anything really happend to the chain, so I would not worry about it at all. The chain will eventually wear out at the pins, not the side of the plates.
BUT I would worry about more fasteners falling off during your trip. So I would get blue threadlocker and re-attach every fastener I can get to with threadlocker.
On my bike no fastener goes back on without it.
AND welcome to the forum. Introduce yourself so we know where you are etc.
Big B, Brockie, Hatchi and 1 others like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #3 of 6 Old 04-27-2019, 08:59 AM
locoblanco's Avatar
Check that the o ring is not damaged, otherwise you are ok.
Motorpsychology likes this.
locoblanco is offline
post #4 of 6 Old 04-27-2019, 09:56 AM
Brockie's Avatar
Your chain will NOT fail because of that wear. If you are soon off on a trip I would take notice of Blaustroms advice and go over all of the bolts on chainguards, mudguards, brackets, etc. and blue Loctite everything. The chainguard shoulder bolts are well known to become loose - they need Loctite. I'll wager that it was the rear one that came loose.
Usually the screw is lost. If you did lose the screw ensure that you replace it with a shoulder bolt.
Big B likes this.
Brockie is offline
post #5 of 6 Old 04-27-2019, 10:02 AM
+1 on it being fine and the blue loctite. I'd oil the chain too while you're at it.
Hatchi is offline
post #6 of 6 Old 04-27-2019, 03:08 PM Thread Starter
Thanks for all the input. The old screw is long gone so I'll have to get a new one and secure it with loctite.
Brockie likes this.
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 04:11 PM
Unusual Chain Wear? strompilot DL650 and DL650A - 2004 to 2011 18 11-04-2013 03:36 AM
Chain Adjustment / Side Stand vs. Center ckellyne Maintenance How-to 39 09-01-2013 09:54 AM
When did you replace your chain? V-Tom V-Strom Service and Maintenance Questions and Discussions 60 05-13-2013 01:40 PM
