vacuum line to no where - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By blaustrom
  • 1 Post By dannyg
post #1 of 6 Old 04-24-2019, 10:26 AM Thread Starter
dannyg's Avatar
Hope I don't get in trouble, posted the same question in different words on the 1000 17+ forum. Before I pull the tank and tear into this, maybe there is a simple answer. On my used 2018 1000 I pulled the tank. Both lines were plugged into the tank, but there was a smaller vacuum line bundled with the other two that I could not find a home for. Any ideas would be very appreciated.
dannyg is offline
post #2 of 6 Old 04-24-2019, 11:39 AM
I could be way off the mark here but could the line you're referring to be the tube the fuel drips down if you overfill or spill while filling the tank? The little catchment area you see when the fuel cap is open? Just chucking it on the wall to see what sticks...
gdrew is offline
post #3 of 6 Old 04-24-2019, 12:57 PM
blaustrom's Avatar
I think no worry. Can't remember but maybe the hose assembly is for CA spec bikes or European with tank fume venting devices. Mine has the same. There is nothing this hose attaches to.
If memory serves me right there are 2 hoses that attach to the tank. One is the vent and the other is the filler neck drain I think.
The circled ones are the ones used, the arrow one is not in use:
Jim L and NVDucati like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #4 of 6 Old 04-24-2019, 02:14 PM Thread Starter
dannyg's Avatar
Wow, That is exactly what I was concerned about. I can not thank you enough. I will try to be quiet for a while.
dannyg is offline
post #5 of 6 Old 04-24-2019, 06:51 PM
locoblanco's Avatar
Possibly a vent to equalize pressure?
locoblanco is offline
post #6 of 6 Old 04-24-2019, 07:36 PM Thread Starter
dannyg's Avatar
It relieved a lot of pressure on me!!
p38arover likes this.
dannyg is offline
Extended front brake line, '13 Wee ABS bendmac DL650A - 2012-2016 24 06-09-2019 11:45 PM
02-12 1000 TB synch with pics and write up "thanks Yarz1" Big B DL1000 from 2002-2012 0 04-16-2018 02:01 PM
SV Racing Parts, Extended Top Front Brake Line Kit for Risers On 2012 Up DL650 abs SV Racing Parts SV Racing Parts 95 08-22-2017 02:46 PM
Vacuum Lines and Breather line Connections DaveInHutto DL1000 from 2002-2012 3 10-04-2014 08:18 PM
