Speed reads 0, od not moving, all else on cluster ok - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-20-2019, 11:51 PM Thread Starter
thecdn's Avatar
Had an hour ride on my 2012 650 up the turnpike Friday for a meeting. Everything was fine. After a four hour meeting I got back on the bike and while everything else on the instrument cluster was good, the speed read zero and the odometer stayed at the same mileage reading.
I've inspected and cleaned the sensors on the wheels. My son, a mechanic, checked the wires on the sensors and the fuses.
I don't have a service manual (assuming my 04 manual for my original bike won't be of much use), will be correcting that tonight.
Anything obvious that I'm not checking? Not so obvious?
Thanks
Orange 2012 Wee (new in May 2013) - Richland Rich's fork brace and mirror extenders, Givi engine guards and top case, gel grips.
Black 2004 Wee with H&B engine guards, SV Racing Frame and Swing Arm sliders, Superbrace, Givi top case, gel grips
thecdn is offline
post #2 of 3 Old 04-21-2019, 09:38 AM
Highwayman2016's Avatar
I can tell you my cluster failed on my 2014 after I rode in a heavy downpour. First the speed started jumping around and then other things went out. I ended up buying a new speedo cluster after checking all the wires. When I got the cluster apart it looked like some water got in the back. Under the advice of a mechanic, I sealed up the top of the cluster cover as best I could with black silicone. Good luck.
2014 650 Strom
Highwayman2016 is offline
post #3 of 3 Old 04-21-2019, 10:27 AM
locoblanco's Avatar
Maybe a problem with the speed sensor/pickup at the front sprocket?
locoblanco is offline
Narrowly avoided high speed collision today Dirt_Dad General V-Strom Discussion 43 10-13-2012 09:41 PM
Moving a WeeStrom on its handlebars... advice/help welcome weeBitTall General V-Strom Discussion 36 08-26-2010 12:05 PM
5 Speed or 6 Speed V Twin Australia-New Zealand 5 12-19-2008 04:02 PM
