Threaded axle... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 32Likes
post #1 of 41 Old 04-16-2019, 08:18 AM Thread Starter
Threaded axle...
Long story short, I am a dumb rookie mechanic to my own vstrom. I threaded my rear axle because I over torqued the nut taking off the wheel and it was a pain in the ass to get off and now I'm afraid to put it back on because the axle threads seems broken. See picture attached. Are my options to buy a new axle or to fix the threads on the axle?
Many thanks
Max527 is offline
post #2 of 41 Old 04-16-2019, 08:32 AM
K9 Wee's Avatar
Looks like you suffered from thread galling....occurs because of the dissimilar metals used. It is a common enough issue that the legendary Greywolf advised anti-seize be applied and torque setting reduced to 58 lb ft to compensate for lubricity--before this happens. Unfortunately, you did not get the memo in time.
Replacement is warranted and if you do a quick search on this, you'll find lots of stories and recommendations. Hope this helps.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 25L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #3 of 41 Old 04-16-2019, 08:40 AM
It is called galling. You can find all about it here with a search on axle torque and galling. I would say new axle and nut. I used never seize the first time I disassembled the rear and under torqued. That is what I did but could not recommend to anyone taking any action other than the manufacturers recommended corrective procedure. kfh000
kfh000 is offline
post #4 of 41 Old 04-16-2019, 08:42 AM
How new is the bike? Any warranty remaining? If bought from dealer I would ask for a new axle and nut.
kfh000 is offline
post #5 of 41 Old 04-16-2019, 09:16 AM
Webfors's Avatar
Hmm.. just torque'd mine down to 72.5 this past weekend. Is the recommendation to use 58 and use red thread locker? Do you have a link to GW's post?
Two wheelz for realz!
Webfors is offline
post #6 of 41 Old 04-16-2019, 09:28 AM
Highwayman2016's Avatar
No, anti-seize and 58 foot pounds.
2014 650 Strom
Highwayman2016 is offline
post #7 of 41 Old 04-16-2019, 09:33 AM
Webfors's Avatar
Ahh, thank you for clarifying! I bought red locker with the intent of putting that on.
There's no concern of adding some lubricity to the axle threads from the anti-seize? I have nickel and copper based AS. Any preference?
I suppose I could just re-torque periodically to give me the warm and fuzzy if I'm concerned about the torque setting.
I'm going to redo that tonight. I would hate to run into this scenario.
srevac likes this.
Webfors is offline
post #8 of 41 Old 04-16-2019, 09:42 AM
That is why the lower torque is used, because of the lubricity and the anti-sieze stops the galling. I have been doing it that way for a couple years, axle has not come loose. I have the silver stuff, I think the copper is for higher temps and should work fine.
2014 650 Strom
post #9 of 41 Old 04-16-2019, 04:37 PM
K9 Wee's Avatar
Have always wondered if this happens more when bike is warm and axle is expanded form heat from riding...stone cold question.
2009 Orange DL650
Givi e22L Sidecases
Shad 33L Topcase
K9 Wee is offline
post #10 of 41 Old 04-16-2019, 05:23 PM Thread Starter
Thanks for the info guys. I ended up managing to get bolt back on and off and on again. I bought a torque wrench and anti seize. 58lbs it is!
Hatchi likes this.
Max527 is offline
Rear axle thread galled Rubicon General V-Strom Discussion 203 02-20-2019 01:39 AM
Rear axle and nut stripped hostler DL650A - 2012-2016 20 11-05-2018 12:36 AM
Rear axle nut binding to axle on DL650A 2013 bunta Maintenance, Tech and Products. 3 12-25-2015 02:44 PM
wtf... is axle runout mean and what problems can it cause? amagictouch007 DL650 and DL650A - 2004 to 2011 4 08-31-2015 01:38 PM
Rear Axle Nut Locking Methods / Issues ? Harry Dresden PI General V-Strom Discussion 9 02-08-2014 12:14 PM
