Center stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #1 of 20 Old 04-13-2019, 11:25 AM Thread Starter
Center stand
Just scored a OEM center stand on fleabay for $199 shipped. Hope they are easy to install.
RandyinTN is offline
post #2 of 20 Old 04-13-2019, 11:55 AM
Randy, they are very easy to install. The ONLY thing that may cause you some grief is installing the springs. For that I use a brake spring tool, but a #3 Phillips screwdriver will work also.
Pay attention to the orientation of the spring ends, and I use red loctite on all of the mounting bolts.
This stand is so much easier to deploy than the center stand on my '81 CB750K, or even my old 900 Ninja.
Funny thing...I installed mine, then raised the bike to try it out. I expected a fight, it literally jumped up on the center stand. Was great! But when I tried to take the bike off the center stand, the bike would just slide forward on my slick garage floor. Til I found that if I pulled the bike towards me from the left side it would stay stationary and retract the stand like RIGHT NOW. Easily one of the best additions to my '14 Vstrom1000.
MAZ4ME is online now
post #3 of 20 Old 04-13-2019, 12:43 PM Thread Starter
Thanks for the tips. Dealer wanted $340 installed which I thought was stupid pricey. Installing springs can be tricky and they always have me wearing safety glasses
post #4 of 20 Old 04-13-2019, 02:52 PM
Big Boy's Avatar
Here's a trick for installing springs. Insert coins between the coils to lengthen the spring to the desired length. Hook the ends, then remove the coins.
Big B, blaustrom, Gert and 6 others like this.
W. C. Fields
Big Boy is offline
post #5 of 20 Old 04-13-2019, 03:12 PM Thread Starter
What a great idea! I can finally do something useful with a handful of pennies as well
Big B likes this.
post #6 of 20 Old 04-13-2019, 07:27 PM
dudu's Avatar
I wish I had known this trick before... This could have saved me some bruised knuckles!
Big B likes this.
Insert witty comment here
dudu is offline
post #7 of 20 Old 04-13-2019, 07:28 PM
dudu's Avatar
$199?! That's a smoking deal!! Great score
dudu is offline
post #8 of 20 Old 04-13-2019, 09:07 PM
Stalky Tracker's Avatar
Piece of cake, sort of. I should have the instructions (K6 Wee) somewhere if you need them.
2019 Eastern V-Strom Rally (website) - May 16 - 19, 2019
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #9 of 20 Old 04-13-2019, 09:25 PM
Location: Boise National Forest, Central Idaho Mountains
Very easy
I use paracord, tie onto springs, loop around back wheel, then wrap around a dowel, then twist & pull.
So far I have used this method on my Vee & 2016 NC700X...
Big B, eff and Shakeyjake like this.
cavedweller22 is offline
post #10 of 20 Old 04-13-2019, 11:05 PM Thread Starter
This is as good as time as many to buy a new tool so ordered a spring puller. Only a matter of time before I need one for the garden tractor or my Kioti with a front end loader and back hoe.
Happy Trails center stand woes zener DL650A - 2012-2016 14 04-16-2019 05:37 PM
Center stand + front stand OK? skyguy Maintenance, Tech and Products. 13 09-21-2018 08:10 PM
2013 650 Outback Motortek Center Stand joeslabb V-Strom Modifications and Performance 2 09-11-2018 04:22 PM
Suzuki center stand just bent Bugzy DL1000 from 2002-2012 30 05-07-2018 05:58 PM
Shortening the center stand ? Dandy Doug DL650 and DL650A - 2004 to 2011 4 06-10-2008 06:23 PM
