Center stand - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #11 of 20 Old 04-14-2019, 12:10 AM
https://www.ebay.com/itm/Snap-on-BT-...gAAOSwd-xcmTSn
Randy, I have 2 of these, one is about 50 years old, got when I was 16, the other was for work. That, and a pair of brake spring pliers will do it all for pull-type springs.
With that lever tool, youre done before you know what you did.
MAZ4ME is offline
post #12 of 20 Old 04-14-2019, 03:09 AM
Gert's Avatar
Similar to the tip by cavedweller22, but using the wheel rotation to open the spring set (https://www.vstrom.info/Smf/index.php/topic,1619.0.html). Yes you did read correctly, there are normally two springs, one within the other, on most of the center stands.
Gert is offline
post #13 of 20 Old 04-14-2019, 09:04 PM
vautti's Avatar
Big Boy, thanks for the "coins in the springs" trick! I am altering and replacing my side stand on my 14' Vee, and this trick will come in handy. Vautti
vautti is offline
post #14 of 20 Old 04-15-2019, 08:18 AM
yes wear glasses, yes you made a good call ordering a spring puller. as someone said, pay attention to spring orientation. Use a good waterproof grease as well.
2016 DL1000 ABS
ERockJL is offline
post #15 of 20 Old 04-17-2019, 04:26 PM
Worked for me too.
Shakeyjake is offline
post #16 of 20 Old 04-17-2019, 05:13 PM
Numbercruncher's Avatar
How did the install go?
NC
Numbercruncher is offline
post #17 of 20 Old 04-18-2019, 09:13 AM Thread Starter
Centerstand arrived but still waiting on the spring puller. Suspect it will be installed this weekend.
RandyinTN is offline
post #18 of 20 Old 04-19-2019, 02:52 PM Thread Starter
Install was pretty easy. Read the instructions several times to understand what bolts and spacer to use on each side, pay attention to the spring placement, don’t tighten all the bolts until everything is together. I installed the rubber spacer before the part was on the bike which made it easier. And it would of been a royal PITA if I didn’t have a spring tool. Those springs take some serious effort to pull back.
End result, money well spent
Big B likes this.
post #19 of 20 Old 04-19-2019, 05:49 PM
Administrator
Good job sir, I won't own an adventure bike without a centerstand.
post #20 of 20 Old 04-20-2019, 05:56 PM
eff
eff's Avatar
This is my homemade spring puller from a 5gal bucket. Worked great when I installed my center stand.
I originally devised it for putting exhaust springs on me GasGas.
Sent from my Pixel using Tapatalk
Gert likes this.
2007 V-Strom 650
2004 GasGas EC250
eff is offline
Happy Trails center stand woes zener DL650A - 2012-2016 14 04-16-2019 05:37 PM
Center stand + front stand OK? skyguy Maintenance, Tech and Products. 13 09-21-2018 08:10 PM
2013 650 Outback Motortek Center Stand joeslabb V-Strom Modifications and Performance 2 09-11-2018 04:22 PM
Suzuki center stand just bent Bugzy DL1000 from 2002-2012 30 05-07-2018 05:58 PM
Shortening the center stand ? Dandy Doug DL650 and DL650A - 2004 to 2011 4 06-10-2008 06:23 PM
