Battery tender - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 15 Old 04-10-2019, 09:30 PM Thread Starter
Battery tender
Always add a battery tender to my bikes. Can the 2018 DL1000 be charged through the 12 volt accessory plug or should I hardwire the tender directly to the battery?
RandyinTN is offline
post #2 of 15 Old 04-10-2019, 09:36 PM
When installing a Battery Tender harness, I do neither if at all possible.
I place the positive eyelet on the starter solenoid stud under the battery cable positive cable eyelet. I place the negative eyelet under the bolt of the closest ground. That way there is no battery corrosion on the Tender harness, and if you remove the battery for any reason you dont have to futz with the Tender harness.
MAZ4ME is offline
post #3 of 15 Old 04-10-2019, 10:10 PM
jgendr's Avatar
If you need a Battery tender you just aint riding enough!!!! Ha ha ha ha ha!!!! Put it in the wind brother
Webfors likes this.
2014 DL650 VStorm
jgendr is offline
post #4 of 15 Old 04-11-2019, 02:05 AM
Rolex's Avatar
MAZ4ME has some good points and for your information you can only charge through a accessory socket if the socket is live with power 24/7
As your socket only gets power with the ignition on it will not work.
MAZ4ME and Motorpsychology like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #5 of 15 Old 04-11-2019, 08:15 AM
Fynlcut's Avatar
Since I'm contemplating a 2nd bike, a "pretty one" that won't be ridden during the winter, I'll be needing a tender. So, I'm going to file this away in the "Damn, I need to remember that!" folder.
Fynlcut is offline
post #6 of 15 Old 04-11-2019, 09:57 AM Thread Starter
Thanks, exactly what I needed to know. Hard wire to the battery it is.
post #7 of 15 Old 04-11-2019, 10:35 AM
eagleeye's Avatar
That thought would have never crossed my mind. Very logical idea! All of mine are connected to the battery.
Posts like this are what makes coming to the site worthwhile.
eff and Motorpsychology like this.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #8 of 15 Old 04-11-2019, 10:46 AM
Hogges's Avatar
A healthy lead acid battery can easily hold very close to full charge for six months or more. If it doesn’t it’s time to get a new one. I bet more batteries have been damaged by overcharging from cheap tenders or trickle chargers than by prolonged self-discharge.
Hogges is offline
post #9 of 15 Old 04-11-2019, 11:28 AM Thread Starter
Any time a battery loses power and recharged the shelf life is reduced. Before I started using tenders I couldnt get more than 3 years out of a battery for a bike or ATV.
After tenders, I have yet to replace one.
post #10 of 15 Old 04-11-2019, 12:05 PM
Many here live in the frozen North and some just don't ride that much regardless of where they live, so a battery tender just makes good sense.
Webfors and Motorpsychology like this.
Put her to sleep. RebornRider New England 58 04-01-2019 08:45 PM
Vee2 hard start and then disaster, oil leak guitstik DL1000A - 2014-2016 80 12-04-2018 07:53 PM
Battery Tender Questions JoeInLex General V-Strom Discussion 22 05-24-2012 03:00 PM
Battery Tender and Gel Batterys deliverydave General V-Strom Discussion 13 11-14-2010 04:14 PM
