Another chain challenged fool. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 25Likes
post #1 of 20 Old 04-09-2019, 08:32 PM Thread Starter
Fynlcut's Avatar
Observations?
It honestly doesnt look that reddish in person.
Is that a missing o-ring?
It has one real tight spot.
It has 17k abused miles.
Fynlcut is offline
post #2 of 20 Old 04-09-2019, 08:44 PM
Originally Posted by Fynlcut View Post
Observations?
A few observations: (1) Rust on the surfaces that can abrade the O-rings (or X-rings) away is the worst. It looks like you have rust there but not elsewhere; and (2) Rust elsewhere is pretty much harmless. Where chain surfaces meet the sprockets, it will be worn away to insignificance. Where chain surfaces touch nothing else, rust is a purely cosmetic issue.
I expect the pictured chain will start growing in length soon. Once the sealing O-rings vanish or become ineffective, the lubricant they hold in gets out. Then the serious, significant wear begins.
DesertBike and eff like this.
Trepidator is offline
post #3 of 20 Old 04-09-2019, 09:10 PM
PineLaneRider's Avatar
Replace it now! This coming from a guy with a holed case due to chain neglect. I lubed faithfully, adjusted properly, just never really checked for stretch or tight spots or shot o-rings or side play. Ended up beside the road with a ruined engine and a puddle of oil. Just a word of friendly advice.
PineLaneRider is offline
post #4 of 20 Old 04-09-2019, 09:25 PM
Stalky Tracker's Avatar
I'd replace it. How does the front sprocket look?
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 20 Old 04-09-2019, 09:30 PM
Motor7's Avatar
Amen...
That rust is the sign of death, chain is toast. Go to sprocketcenter.com and order a new chain and sprockets...DID, RK, EK are all quality chains.
https://sprocketcenter.com/motorcycle-chains.html
EK have optional screw on master links...no special tools required.
Big B and DesertBike like this.
15 DL650XT
Motor7 is offline
post #6 of 20 Old 04-09-2019, 09:39 PM
MontanaGuy's Avatar
It makes me a bit nervous also. I would also check the chain by trying to lift it off the back sprocket at the three o'clock position. If you can pull it away much at all, the chain is done. (Done with the chain adjusted as well as can be.)
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #7 of 20 Old 04-09-2019, 09:58 PM
VSrider's Avatar
Another case of chain abuse. Replace it and take care of the new one. Lube every few hundred miles, (to preserve o-rings, prevent rust and give lube to the rollers and sprockets), and keep an inch and a half slack in it.
Big B and K9 Wee like this.
VSrider is offline
post #8 of 20 Old 04-09-2019, 10:06 PM
Definitely don't chance it. A broken chain can take you down and end your life.
Lrobby99 and Webfors like this.
06 V-Strom DL650
John V Strom, Jr. is offline
post #9 of 20 Old 04-09-2019, 10:14 PM Thread Starter
Fynlcut's Avatar
Yeah, Just the tight spot and the frequency of needing adjusted told me it was past due.
I'll see if the local shop has one in stock tomorrow, or I'll put one on order. I know squat about chains so I'll have to figure what type, size, color, smell, taste...... However you pick out a chain
I also know it's my fault because my commitment to the lubrication gods have been horrid. I'm probably going to live my after life in a horribly dry abrasive hell.
When I did lube it was with chain wax and I think the original application was still gunked up on the non important parts of the chain when I cleaned it a few weeks ago. I think it lulled me into a false belief it was still doing its job.
Now I have one of those fancy auto lube thing-a-ma-bobs.
I had a shaft drive before this. I'm not so lazy with the rest of my maintenance. Well maybe my cleaning regiment is almost nonexistent, but who needs a clean wee?
Fynlcut is offline
post #10 of 20 Old 04-09-2019, 11:38 PM
The vendors on this site can sell you quality chains and sprockets for a competitive price. I got a POS chain from a dealer and it didn't last long. Cheaping out isn't the way to go.
Not cleaning the Srom is OK, just don't forget to lube the needy parts.
Webfors likes this.
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 12:12 PM
Chain Slack Rebel Trepidator Maintenance, Tech and Products. 37 03-06-2015 06:24 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 04:11 PM
A (Personal) Caution on Using Dupont Teflon Chain Lube, (Some Pics) Black Lab General V-Strom Discussion 73 11-26-2009 03:03 PM
