Tuturo Oiler Questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 13 Old 04-02-2019, 11:16 PM Thread Starter
jmf552's Avatar
I've seen the Tuturo Chain Oiler discussed a lot here I plan to get one and install it on my 2014 DL650 ADV. I do mostly road riding with a little dirt/gravel road stuff. I have a few questions and would really appreciate input from those who have a lot more experience (which is pretty much everyone!).
  • The Tuturo site shows "Pro" "Deluxe" and "Standard" kits. What do you recommend? It looks like the Standard kit would have everything needed, but I have no experience.
  • I have read here that the twin nozzle does not actually work as well as the single. True?
  • Do you use Turturo oil, or have you found something that works as well?
  • They show some optional accessories, such as a "Stone Shield" a "Nozzle Positioning Kit" and a "Helix Nozzle Positioning Device." Any of those useful?
Thanks.
Self-medicating two-wheel therapist...
jmf552 is offline
post #2 of 13 Old 04-03-2019, 02:02 AM
Highwayman2016's Avatar
I just use the single nozzle and Tutoro oil. There are suggestions on the Tutoro website of what alternative oils will work, but a quart lasts quite a while. I ended up with 1/4 to 1/2 turn on the valve. Works great, just used what came in the kit no accessories.
Big B and richlandrick like this.
2014 650 Strom
Highwayman2016 is offline
post #3 of 13 Old 04-03-2019, 04:11 AM
ScottTheFalcon's Avatar
Standard unless you need the brackets
I've put the Pro on my DL650, and the standard on my SFV650.
The pro comes with a handy extra bracket that while good you can probably work around, depends on the bike a lot.
The DL650 is running my second dual nozzle, the SFV is running its first single. The single is certainly more robust - the dual is pretty fragile. They probably work as well as each other. My DL650 also has the stone guard - probably don't need it but I thought - rocks and all...
I ended up 3d printing a bracket for the SFV as it was problematic.
If I was you I'd buy the basic kit, single nozzle and work it out. But use their oil - you use so little of it may as well use original.
ScottTheFalcon is offline
post #4 of 13 Old 04-03-2019, 07:09 AM
Griff2's Avatar
I found that the double nozzle was a nuisance when remounting the rear wheel. Imho it is not necessary and thereafter I always went with a single nozzle which worked as well.
I have used all sorts of oils in my Tutoro. Usually it is a good quality oil left over from bike or car oil changes. A fiend uses chainsaw oil that is used for lubing the cutting blade. The Tutoro is not fussy 😉
The Standard Kit is sufficient to do the job.
Lastly this is imho one of the better chain oilers. My former Scottoiler always made a mess around the rear wheel despite my best efforts at adjustment. The Tutoro flow is much more precise and easier to modulate.
richlandrick likes this.
Griff2 is offline
post #5 of 13 Old 04-03-2019, 09:05 AM
I run the deluxe and the single nozzle, their oil is the best IMHO and a container lasts a very long time. I too am 1/2 to 1/4 turn depending on the temps, I find this to apply the oil just about right.
post #6 of 13 Old 04-03-2019, 02:17 PM
I am using the single tip Tutoro, even though I bought the delux kit. The oil and bottle that comes in the delux kit comes in handy.
In terms of oil. I am finally finishing up the oil that came with the delux kit. it's been almost one year.
In its replacement, I have heard the Hydrolic Mobile Vactra can be used. It's certainly cheaper than the Tutoro Oil.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #7 of 13 Old 04-03-2019, 03:35 PM
Here’s Tutoro’s suggestions for oil.
https://www.tutorochainoiler.com/pag...l-should-i-use
2014 650 Strom
post #8 of 13 Old 04-03-2019, 03:42 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
All good stuff above. Single feed nozzles work fine, are far more robust, an dirt cheap to replace. Lowe's has some 1/8 tubing that looks identcal to the 3 mm Tutoro single feed nozzles so you never have to go without. Get a life to supply for a couple of bucks.
Big B, OCADVR and EddieFL like this.
richlandrick is offline
post #9 of 13 Old 04-03-2019, 03:56 PM
Lots of good info for you here. As to oil, ordering from Tutoro, the shipping is as much or more than the oil! I’ve been running ISO 32 hydraulic oil. Picked up a gallon at Home Depot for around $13 that will last a looonnng time. I may try an ISO 68 as the 32 may be a little thin for higher ambient temps although now that I’m out of Florida, that may not be as much of an issue.
2015 V-Strom 650XT ABS
1969 Triumph Bonneville
EddieFL is offline
post #10 of 13 Old 04-03-2019, 07:21 PM
VSrider's Avatar
Yee Haw. Finally got mine working again. I glued a piece of rigid stainless tubing to the Tutoro bracket on the swing arm. It has a bend towards the sprocket at about a 45 degree angle and at the end has a one inch piece of tubing just barely touching the sprocket at about the 7 o'clock position. No nozzle. They kept falling off. Now my chain should go 100K miles, that is if I keep the bike that long.
Big B likes this.
VSrider is offline
Tutoro Auto Chain Oiler Review and Installation Strongarm Product Reviews 58 02-28-2019 08:38 PM
Loobman Oiler Summation senoje DL650A - 2012-2016 19 10-01-2017 09:18 PM
Scott Oiler Questions WiredDriver Maintenance, Tech and Products. 13 02-17-2012 12:47 PM
v-n00b has a few questions, + first experiences on a wee xaphod General V-Strom Discussion 6 07-08-2008 04:17 AM
Newbie's V-Strom Questions hschisler General V-Strom Discussion 25 03-15-2008 10:58 PM
