HELP! I've done something really stupid! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 22Likes
post #1 of 18 Old 03-03-2019, 05:45 AM Thread Starter
I now have a piece of broken plastic funnel in my engine oil.
I've just done an oil and filter change for the 54,000km service. Standard procedure -- top the oil up, run it to fill the lines and filter and top it up again.
However I left the funnel in the filler cap when I cranked it the second time and a small piece of plastic has been ripped off the funnel into the motor. (Faaaarrk. What a dufus!) It's about maybe 8mm x 5mm in size
I've now got the bike on my trailer to visit a shop. I'm assuming that the sump and clutch cover have to come off and the whole system flushed unless they find the piece intact.
Do I have any other options??
FoggySwamp is offline
post #2 of 18 Old 03-03-2019, 07:20 AM
Brockie's Avatar
I'd drain the oil first - it might just float out.
Brockie is offline
post #3 of 18 Old 03-03-2019, 08:46 AM
Yes, you might find it will come out if you drain the oil. Drain it first and look for the piece. If not there, buy a gallon of cheap oil at WalMart and pour it in the engine while the drain plug is out. That could push it out.
I would then probably pull the clutch cover. You will need a new OEM gasket, but the task is fairly easy and straightforward, the coolant being the pita part. You still won't be able to get into the sump, but you might be able to flush it out of there easier this way.
VSrider, Gert, Brockie and 4 others like this.
realshelby is online now
post #4 of 18 Old 03-03-2019, 10:19 AM
Brockie's Avatar
I don't know if you have a main stand but drain, and flush, while the bike is on the side stand.
DesertBike likes this.
Brockie is offline
post #5 of 18 Old 03-03-2019, 11:35 AM
VSrider's Avatar
If you can't find it hopefully it will get caught in the filter. Next oil change cut open the filter.
VSrider is offline
post #6 of 18 Old 03-03-2019, 12:35 PM
blaustrom's Avatar
Does the plastic material foat or sink in oil? Depending on the answer I think different strategies may be advised. If it foats it should come out provided it can pass the oil plug opening. If it sinks it may not want to come out by draining, but also may not be a big problem just sitting in the sump. The oil pump has a strainer (#10) screen that will prevent it being sucked in unless it has been hacked to small bits. In that case the bits will end up in the filter. I would not take drastic action trying to get that piece out if it does not float out by draining the oil. Eventually it will come out.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #7 of 18 Old 03-03-2019, 12:57 PM
Run the oil through a kitchen strainer as you're draining it, be easier to find the plastic if it comes out.
gdrew is online now
post #8 of 18 Old 03-03-2019, 03:53 PM
bighammer's Avatar
Whether it sinks or floats, I don't picture it becoming a problem either way. The pump draws oil from near the bottom, but wouldn't pull it off the bottom. If it floats, it will never get down to that level. Either way, there's a screen that would catch it. I wouldn't worry about it.
2018 Flee-Strom 1000XT
bighammer is offline
post #9 of 18 Old 03-03-2019, 08:11 PM
It all depends on if it melts or not.
StratStrom is offline
post #10 of 18 Old 03-04-2019, 12:03 AM
blaustrom's Avatar
So what if it melts, then it become a sphere. And you can test that as well at what temperature it does melt. I would bet it only softens at operating temperature. Anyway it's not going to go through that pump strainer. At worst it may plug up a fraction of that strainer surface area but I highly doubt that will happen.
Blau2 2014 DL1000A
Vstrom model name shortcuts greywolf General V-Strom Discussion 141 04-04-2018 09:47 PM
Stupid stupid stupid Dread angel Riding Proficiency 24 02-20-2016 03:03 PM
Stupid is, blew my ECM nomorbills DL1000 from 2002-2012 16 05-18-2011 12:51 PM
Stupid, Stupid Face Plant BgDadddy General V-Strom Discussion 55 04-08-2009 06:32 PM
Stupid Stupid Stupid.... Blue-Strom General V-Strom Discussion 5 07-14-2008 10:55 PM
