Instaling Cruise Control in 2018 DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 3 Post By Motor7
  • 2 Post By Rolex
  • 1 Post By realshelby
post #1 of 10 Old 02-26-2019, 08:36 PM Thread Starter
Hello guys,
Im trying to install the CCS100 cruise control in my 2018 DL650 Vstrom.
Followed the instructions, but system does not work.
Gone to the troubleshooting section of the installation manual and opened de cover on cruise and looked at the LED. Than:
a) Press Set button, and LED LIGHET properly. Seens ok, right?
b) Press Resume button, and LED LIGHET properly. Seens ok, right? But
c) Step on the brake, but LED DOES NOT lighted. Seens something is NOT RIGHT, ok?
Dont know if somebody can help giving any tips to fix it.
Any help is very appreciated !!!!
Thanks a lot.
Stormer is offline
post #2 of 10 Old 02-26-2019, 08:56 PM
Motor7's Avatar
I am only familiar with the Rostra units, so here is my 2 cents. If any LED light bulbs or auto flashers are installed on the bike you will need a relay to make the CC work.
pvwheeler, EddieFL and Stormer like this.
15 DL650XT
Motor7 is online now
post #3 of 10 Old 02-27-2019, 01:56 AM
Rolex's Avatar
I agree with Motor, your LED brake light is the most likely cause of your problem and it will require a relay to bypass the LED.
pvwheeler and Stormer like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 10 Old 02-27-2019, 10:07 AM
The Rostra and Audiovox are the same unit.
Did you run the "diagnostics" test as prescribed in the manual?
There does seem to be some issues with the brake light not tripping the cruise control on the later DL's.
Stormer likes this.
realshelby is online now
post #5 of 10 Old 04-17-2019, 12:15 AM
Does this work on the 17', 18', & newer Wee ? If it does, can you post the entire setup as I have so far been unsuccessful. I have run the diagnostic and installed the brake light relay without success. I have installed 7 CCS-100's on sv & dl 650's & 1000's, Triumph 1050 Tiger and an FJR. PLEASE save me from this cruise control nightmare.
Kelrich is online now
post #6 of 10 Old 04-18-2019, 10:43 PM
Motor7's Avatar
Go back over everything you did. The first one I installed I could not get it to work and doubled checked all connections. After a couple of days of frustration I was just gonna yank the damn thing. Turns out the throttle bead had pulled out of the stupid little U clamp that comes with the Rostra to move the linkage. Some JB Weld fixed it and it's still working 6 years later.
So what did the diagnostic tell you?
15 DL650XT
post #7 of 10 Old 08-20-2019, 08:53 PM
Hi Stormer.
I am trying install rostra CC in a 2018 wee XT a couple months and until know all effort was unsuccessful.
You were able to perform the installation ?
If you were able to install, could you provide the wiring diagram and what you found different in the installation compared to the wee 2 models?
I'll be very thankful.
wagnerjudice is offline
post #8 of 10 Old 08-21-2019, 12:00 AM
I mistakenly thought the CCS100 control pad worked with the Rostra. By the time I got the correct pad I probably fried something in the Rostra unit. Will be trying again with a new unit next month when things slow down. Most of the problems I've seen are with the LED taillight. The relay setup is critical as I found out on my 08' Tiger.
post #9 of 10 Old 12-03-2019, 09:22 PM
Hi thereMotor 7
I installed the rostra cruise control in my Wee3 (2018) and using open circuit control switch. The 12 programming switch were configured to 1-off, 2-off, 3-off 4-on, 5-off, 6-on, 7-on, 8-on, 9-off, 10-on, 11-off, 12-off. I did the self diagnostic testing and all procedure were ok according TROBLESHOOTING manual of Rostra. I took a ride to test the cruise and ON light of switch was ok, engaged light turned ON when pressed set/cost, when press the bake the engaged light cames OFF, press again set/cost engage light comes ON. So, there are no problems with lights of control switch or diagnostic light (it worked as expected in the self diagnostic). But, the rostra did not worked as expected. When I release the accelerator the speed does not hold. The cable throttle of rosta in the body throttle on Wee it is strained.
In attach it is the wiring diagram that I used to installation follow your previous drawing.
If you have some advise I will be very grateful.
post #10 of 10 Old 12-04-2019, 03:25 PM
Motor7's Avatar
Wagner, if the cable/ with beads is too tight or too loose, it will cause issues. Since you said it was tight, I would give it one bead length slack and try again.
If you are using the cables provided, then switch to the length of beads since the cables are made in a pre determined length.
15 DL650XT
Rostra Electronic Cruise Control Install Instructions larolco Maintenance How-to 231 10-01-2019 09:59 AM
Rostra Cruise Control Alternate Wiring Strom Chaser V-Strom Modifications and Performance 26 07-02-2015 10:35 PM
Cruise control for SV650, cruise or speedometer-but not both rfulcher V-Strom Modifications and Performance 0 08-22-2010 10:22 PM
