Heated Grips - How did you route the wire? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-22-2019, 02:42 PM Thread Starter
I'm installing Oxford Heated grips on my '13 DL650. The bike has Suzuki's factory plastic handguards.
How did you route the power cable for the throttle side so that it does not jam the throttle against the handguard? I'm assuming the best routing will be with the throttle cables, but what is the starting point (throttle closed)? All of my trials seem to have the cable jamming against the plastic guard if I leave enough slack not to restrict opening the throttle.
To make descriptions easier, imagine a clock face on the end of the handlebar looking toward the master cylinder. Were the wire to exit the grip horizontally pointing forward, that would be 3 o'clock. And so on....
Ratchet is online now
post #2 of 7 Old 02-22-2019, 03:58 PM
eff
eff's Avatar
I'm just getting ready to install them on my '07 Wee, but see if this helps.
https://youtu.be/aX4mV8XyPI8
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #3 of 7 Old 02-22-2019, 08:09 PM
Rolex's Avatar
We would all love to hide the wires but it is just not possible.
On my V2 I have it so the wire rests on top of the handguard (bark buster) in the closed position, that way it is free to rotate as required.
Give yourself enough slack to reach wide open throttle (WOT), cable tie to the throttle cables but don't have your first tie too close to the throttle tube, about 5" to 8" down works, this gives the wire more freedom to move.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 7 Old 02-22-2019, 10:18 PM
Kivuli's Avatar
I have a friend with a '13 Wee2 with those grips. The wire is located top dead center when closed and it works. I have those grips on my '09 Vee and I have the wire bottom dead center and it also works. Both have factory barkbusters.
Sarafina - 2009 DL1000
Kivuli is offline
post #5 of 7 Old 03-31-2019, 08:49 PM
Webfors's Avatar
I played with several positions when I installed mine. Settled on the cable at the 7-8'ish o'clock. Works great, doesn't jam anything and easily routes with a couple of "loose" zip ties. You don't want to tie the cable down tight, at least the first couple ties... it needs to move.
Pics:
https://www.dropbox.com/sh/920r0k9g5...MRh31wnga?dl=0
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #6 of 7 Old 03-31-2019, 08:50 PM
Webfors's Avatar
Oh, and I LOVE these heated grips... -4 degrees out and at 100%, hands are toasty warm, even hot at times.
'18 DL1000XT
post #7 of 7 Old 04-05-2019, 10:34 AM
bwringer's Avatar
I have grip heaters on all my bikes, and the wire is routed along the bottom side of the bar, sort of arced underneath the switch pod, then enters the grip at about the 7:00 position. Never had an issue or a snag this way.
So basically, the wire is secured with a Ty-Rap to underside the bar on the other side of the switch pod, then there's an arc or loop crossing under the switch pod to accommodate rotation.
bwringer is offline
heated grips replacement Russ General V-Strom Discussion 4 06-09-2015 03:39 PM
Best place to wire in heated grips dazzarulz1990 General V-Strom Discussion 11 05-21-2015 01:14 PM
6$ HEATED GRIPS? Your nuts. T-ville Trooper General V-Strom Discussion 37 02-25-2012 01:16 AM
Symtec heated grips stopped working on the Golden Gate Bridge today arooni V-Strom Service and Maintenance Questions and Discussions 1 09-10-2011 07:40 AM
