Can't Get to That Front Spark Plug! Any Tips? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 14 Old 02-17-2019, 10:38 PM Thread Starter
Ron Strommer's Avatar
Hey guys,
I've got the tank off of my 2018 1000 to swap out the air filter. The bike has 25,000 miles on it so I'd like to replace the plugs while I'm under there and not worry about them for a while. Yes, I know they can probably go much longer.
As you know, the back three are easy but that one behind the radiator is a pain. The service manual just says to remove the mounting bolts and move it forward which I did but it doesn't move much and I can't quite get my hand in there enough to get a good grip on the cap. I am contemplating removing radiator which I'd like to avoid.
Any tips or tricks?
Ron Strommer is offline
post #2 of 14 Old 02-18-2019, 12:07 AM
For what it's worth, I couldn't get my average sized hand in there either. I removed the top radiator hose, made a mess, cleaned it up and changed the plug. If there is a trick- I couldn't figure it out. The second time I removed some coolant first.
There just doesn't seem to be enough give in the hoses to get the space I needed. Good luck.
moglink is offline
post #3 of 14 Old 02-18-2019, 01:04 AM Thread Starter
Thanks. That's what I wound up doing too. Then I put the hose back on and drained the rest of the coolant. Might as well change that too so I can forget about it for another 30k or so miles. Moving the radiator forward with those hoses still attached as the service manual states simply does not proved enough room.
post #4 of 14 Old 02-18-2019, 11:01 AM
Only 30K interval? I changed mine at 80K miles due to a valve check and they looked fine. I only changed them since I had a set with me.
I noticed no difference in the way the motor ran with the new plugs.
The suggested replacement interval for my old beemers was 10K. I gave up on that and can't remember a plug ever fouling out or burning up.
post #5 of 14 Old 02-18-2019, 12:25 PM
dravnx's Avatar
After loosening the radiator use the spark plug tool out of the tool kit. It works.
chicago, bwringer and Vstrom Sid like this.
L2 DL650 Adventure
bike X miles=smiles
smiles ÷ bike=miles
smiles ÷ miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #6 of 14 Old 02-18-2019, 01:33 PM
I forgot about the tool kit- will try that next time... if there is a next time.
As for the durability of iridium plugs, I guess I had to see for myself. Changed them as recommended (~17k?) the first time, and then around 50k the second time. No sign of wear or fouling either time but when I got to that point it was just as easy to put the new ones in. Live and learn.
FYI- The specified NGK plugs can be had through NAPA at $9ea rather than the $25 through cycle stores. Same number, gap, etc.; everything but the Suzuki logo on the box. Ordered online and went to my local store when they arrived in a few days.
moglink is offline
post #7 of 14 Old 02-18-2019, 06:13 PM
that BS in a car Iridiums rated for 120,000 miles
richw is offline
post #8 of 14 Old 02-18-2019, 08:24 PM
STCorndog's Avatar
That is my feeling too. Although, in a car, the average RPM (cruising to peak) is probably 1/2 what it is in the Strom. I changed mine in the 07 Strom at about 50,000 miles and they looked pretty good still.
As for getting in there, I used the socket in the toolkit also. I loosened the radiator mounts, put a heavy piece of cardboard between the radiator and my tools, and cussed.
Stalky Tracker likes this.
STCorndog is offline
post #9 of 14 Old 02-18-2019, 09:31 PM
Spec's Avatar
A bike fires all the plugs every crankshaft revolution not just on the compression stroke. Bikes rev higher than cars too.
The recommended service internal is overly cautious probably but no way will you get the same life as in a car.
Spec is offline
post #10 of 14 Old 02-18-2019, 09:48 PM
STCorndog's Avatar
Spec,
That is a good point and one I lost a bet on with another gear-head at work. You could be right and you could be wrong. Depends on the engine. If you have points on an older engine, it depends on where the points take their signal from, the cam or the crank. Further, on modern cars with coil on plug ignitions, they can fire every crank revolution just like a modern bike does.
I think I lost my bet by technicality, but he had me thinking about it which was worth the effort.
Spec likes this.
2003 DL1000 front spark plug replacement Vglider DL1000 from 2002-2012 4 11-10-2015 10:24 PM
Drenched engine, half power gatorcog DL650 and DL650A - 2004 to 2011 10 05-19-2015 10:15 PM
Spark plug colour difference between front and rear cylinder. rd_no V-Strom Service and Maintenance Questions and Discussions 3 11-26-2013 08:41 AM
K&N or irridium plug-- improvement? marku DL650 and DL650A - 2004 to 2011 51 02-01-2011 06:13 PM
