Driving light switch wiring help. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-14-2019, 06:56 AM Thread Starter
DaveinNC's Avatar
No, it's not a Strom but wiring is wiring. I am installing a set of Baja Designs Squadron Pro driving lights on my VFRX, I procured an OEM factory unlit fog light switch from Great Britan. It has 2 wires, the illuminated switch from the Baja Designs harness has 3 wires. I am assuming the 3rd wire is for switch light power, correct? Do I just cap off the hot lead to the 3 wire switch? If not what do I do to get the 2 wire switch to trigger the relay? I am an electrical moron, unless I have a schematic in front of me I am lost, so any help would be appreciated.
"Dave"
DaveinNC is offline
post #2 of 5 Old 02-14-2019, 08:40 AM
Originally Posted by DaveinNC View Post
wiring is wiring.... what do I do to get the 2 wire switch to trigger the relay?
one reference I typically go back to when I want to set up a schematic before I wire in a relay is this site: Electrical Items - LDRiders There are a number of helpful explanations, and one of them is Relay Installation.
Yarz1 is offline
post #3 of 5 Old 02-14-2019, 12:00 PM
vanislejay's Avatar
You are correct, but which wire you cap off depends on if the switch is designed to switch the positive or negative leg of the circuit.
2003 DL1000
Too much other broken stuff to list
vanislejay is offline
post #4 of 5 Old 02-14-2019, 12:25 PM
I'm an electrical engineer and often find it challenging to work on systems without a schematic.
It would help to know a few things before offering advice. (Otherwise, it would be conditional and complex.)
1. Do you have a headlight relay already installed on the bike?
2. Do you want to enable the indicator function that the 3-wire switch makes possible? (Your post suggests maybe not.)
3. Do you have, or are you willing to obtain, a (likely cheap) digital DMM with which to figure out what the 3-wire switch is?
4. Would you like (or be willing to accept) the driving lights being forced off when the headlights are off?
Last edited by Trepidator; 02-14-2019 at 12:30 PM. Reason: punctuation, added question
Trepidator is offline
post #5 of 5 Old 02-14-2019, 01:36 PM Thread Starter
DaveinNC's Avatar
Thanks, everyone that replied, I got it worked out. The data or switch power wire gets capped unless I run the dimmer, then it gets spliced. Thanks.
"Dave"
DaveinNC is offline
Driving light advice [email protected] DL1000A - 2014-2016 35 04-19-2016 04:38 AM
Reading Wiring Diagrams middie26 General V-Strom Discussion 16 07-20-2011 05:21 PM
New camp light/trouble light penny mod docsabre Maintenance, Tech and Products. 0 06-28-2011 06:26 PM
That danged parking light switch...! MoDaddy General V-Strom Discussion 20 12-18-2010 12:14 PM
