The axle ground at an angle, so the threads on the back are fine. Maybe 50-60% has damage and for only a small portion of that the threads are totally gone. It's a good point about getting it off on a trip. I'll be close to home for the rest of the winter so it won't be a concern for awhile, but once it's spring I'll take care of it. The problem with trying to re-use them is that I'd take gamble not having a new axle and nut on hand in case either one gets too messed up taking it apart to re-use. And if I've got it on hand already I might as well replace them
Final verdict is that the handlebar is bent slightly. Adjusting the bars back down made them feel better, but the slide (right) side is still off. I can barely see it by looking closely from a few feet back and can more feel it. Not sure if a replacement will be necessary, obviously the whole once metal is bent it's weaker thing applies but it's real minor.
All in all I'm impressed with how well Suzuki made the bike. It wasn't the worst wreck, but still a decent slide and she held together great. Even the stock saddle bags didn't totally give it up! And if anyone doesn't like the plastic along the tank... I found the use for it now as it protected the tank very well.
Washington! Eastside Seattle area. Moved from Minnesota recently so there was no way I was going to stop riding during the "winter" here.
