Headlights quit working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 11 Old 12-16-2018, 02:59 PM Thread Starter
Coming home from work the other day ( I live in Alabama) , oncoming cars started blinking their lights at me. I thought it might’ve been an accident ahead but it became apparent as it became dark my headlights were kaput. Where should I start troubleshooting this situation since there are no loose wires and it has a fresh battery. Your help will be appreciated!
trussvilletom is offline
post #2 of 11 Old 12-16-2018, 03:37 PM
New rider here with not much experience wrenching on the bike, probably because it is so reliable. You don't say what you have tried but I would put 12 volts to the bulb to see if it is out or is there a problem further up the line. If the bulb is out then how old/many miles on it, is it just bad luck was it time or a rock hit or is there an issue in the wiring. If the bulb is good I would go up the line with a meter and check the fuse and see where you are losing power.
dogg is offline
post #3 of 11 Old 12-16-2018, 03:41 PM
nvr2old's Avatar
Starter switch. You need a headlight relay after your fix to prevent it happening again. A search should bring up many hits on this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 11 Old 12-16-2018, 03:54 PM
I too would immediately blame the starter switch.
Here's one post to help you, there are MANY:
https://www.stromtrooper.com/v-strom...m-hid-kit.html
Yarz1 is offline
post #5 of 11 Old 12-16-2018, 04:20 PM
High beam out too?
gdrew is offline
post #6 of 11 Old 12-16-2018, 04:40 PM Thread Starter
Thank you, I’ll give it a check!
post #7 of 11 Old 12-16-2018, 04:59 PM
Post #4......very very well known issue with first and second generation 650's and first generation 1000's, yes it is a STUPID and bad design.
post #8 of 11 Old 12-16-2018, 09:50 PM
larolco's Avatar
Probably the switch mentioned above, but I will add my own experience.
I had both headlight bulbs die within one day of each other. It was uncanny. If I hadn't been paying attention and already installed the Eastern Beaver relay, I would have blamed the switch.
So, there is the possibility that the bulbs have just died, but you want to install the relay regardless. And fix the switch if it's fried.
I can also mention that my fuse box has been known to suffer from slow main fuse melting which has caused my headlight circuit (among other things) to fail. There's lots of draw on that baby in the winter when I'm running full heated gear.
If you're swapping out the bulbs, consider going LED. Way less draw and simple plug and play.
DRZ400SK17
larolco is online now
post #9 of 11 Old 12-16-2018, 09:55 PM
Bogfarth's Avatar
Start switch.
Fix the start switch, grab Beamtech LED H4s from Amazon ($40) and then the Eastern Beaver H4 headlight relay kit. Problem solved (shoulda been feexted at the factory tho.)
notacop likes this.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #10 of 11 Old 12-17-2018, 10:52 AM
I'd gotten the Eastern Beaver relay kit used here on the for sale section.
Then I got some $25 LED's and installed them. My volt meter reads much higher charge rate now.
Rostra Cruise Control Stopped Working - Need Help Ned DL650A - 2012-2016 17 05-17-2017 11:43 PM
Brake light quit working rickpcmp3 DL650 and DL650A - 2004 to 2011 6 10-24-2015 10:42 PM
Coocase S48 Luxury Remote and Alarm quit working creisinger General V-Strom Discussion 3 11-10-2013 05:36 PM
headlights, ignition switch and choosing relays (Eastern Beaver or DDM HID kit) the schwartz V-Strom Service and Maintenance Questions and Discussions 10 09-24-2013 09:54 AM
