leaking fuel tank - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 19 Old 11-30-2018, 11:54 PM Thread Starter
Unhappy leaking fuel tank
After putting up with the occasion smell of petrol in the garage I finally decided to investigate.I pulled the black plastic off the right side of the tank and near the bottom of the tank,a bloody pinhole.If I wiped the fuel away I can just watch fuel reappear ever so slowly.Now the question is,is it possible to patch the hole from the outside or do I need to re-coat the inside.I did the re-coat thing about 10yrs ago on a Triumph trophy Tank and found it absolutely NO FUN at all. I'm hoping the wealth of knowledge on the forum may come up with an easier solution.I will pull the tank off and strip it anyway,maybe that will answer the question for me. Thanks in advance for any help or miraculous cures.
post #2 of 19 Old 12-01-2018, 12:02 AM
I just saw 6 DL650 gas tanks on E-bay, ''06 to '11. Dont know if they'll work on an '04.
MAZ4ME is offline
post #3 of 19 Old 12-01-2018, 12:14 AM
Plain old bath soap can stop it leaking as a temporary measure. Just rub it on dry of fuel. Araldite, Plastic steel or any of those tubes that you mix up from your auto store will fix it permenantely.
ozbass17 is offline
post #4 of 19 Old 12-01-2018, 06:32 AM Thread Starter
I took the tank off this afternoon and it looks like it may have been re coated before. There's an Ausi mob who make a kit for this job and according to their literature I may have to do the whole process again,yuck.I think I will investigate one of the other options.
post #5 of 19 Old 12-01-2018, 06:34 AM Thread Starter
I wonder if they are any better than the one i already have
post #6 of 19 Old 12-01-2018, 06:38 AM Thread Starter
\i know Araldite but not plastic steel.I assume you would rub the tank back to bare metal to use this stuff,wouldn't matter ,you wouldn't see it anyway.
post #7 of 19 Old 12-01-2018, 08:09 AM
Rolex's Avatar
Supercheap Auto has the putty for plugging from the outside.
I have used both of the cheaper ones on some of my farm equipment with good results.
https://www.supercheapauto.com.au/se...gment=1&page=1
ozbass17 likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #8 of 19 Old 12-01-2018, 11:11 AM
Fels Naptha used to be a go to soap for stopping a gas tank leak.
You could try taking the tank off and putting it on it's side and clean up the are and put a patch of JB Weld on it?
I JB Welded a crack in the valve cover of BMW. It stayed sealed.
post #9 of 19 Old 12-01-2018, 01:18 PM
A pin hole at the bottom of the tank (where water accumulates) tells me that you are likely rotting outward. I don't know much about recoating the inside but if a tank can be purchased reasonably, IMO, that is the way to go.
realshelby likes this.
'01 SV650N
derj is offline
post #10 of 19 Old 12-01-2018, 01:26 PM
I used JB Weld on a motorcycle fuel tank pinhole before...worked great.
Stalky Tracker and ozbass17 like this.
gdrew is offline
Fuel Leaking at Start Up Oily DL1000 from 2002-2012 7 12-20-2017 02:13 AM
Removing fuel hose from tank stu53 DL1000A - 2014-2016 9 08-26-2017 09:51 PM
Fuel Tank Rust Removal Scootertrash in Paradise Maintenance How-to 14 01-01-2017 11:02 PM
Fuel tank hoses on Glee Bemidjipaul DL650A - 2012-2016 4 01-31-2015 01:16 PM
