DIY Soft Saddlebag Supports - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By notacop
  • 1 Post By Ironlady
post #1 of 3 Old 11-07-2018, 11:00 AM Thread Starter
Ironlady's Avatar
Just finished my shakedown ride with my new homemade soft saddlebag supports, supporting my venerable Cortech saddlebags and tail bag. 35 miles, no problems. When I got to work I stuck my hand into the right saddlebag and felt the bottom, which rests on the muffler at the very back. It was barely warm, but I will be adding a layer of heat-deflecting material to the bottom of that saddlebag anyway. I will also be rounding and smoothing the corners of the brackets. I really prefer the narrower profile of soft bags, which can hold an amazing amount of stuff. The soft bags can also act as pretty effective "air bags" if you happen to drop the bike.
I made these brackets out of one 4 foot section of aluminum strap from Home Depot. It's 1 inch wide, 1/8" thick. (May change to thicker material in the future; let's see how this works out.)
Ironlady is offline
post #2 of 3 Old 11-07-2018, 11:03 AM
The inward droop might go away with another bit of strap going from side to side behind the rear end? Lots of regular bag racks have such a brace.
Gert likes this.
post #3 of 3 Old 11-08-2018, 06:48 PM Thread Starter
Ironlady's Avatar
Nope. There's already a strap across the top of the taillight pulling the tops together. Inward droop is not a problem as long as the bags don't "droop" into the rear wheel, which they did before I made the supports.
richlandrick likes this.
Ironlady is offline
Tags
luggage , luggage mounts , saddlebags , soft saddlebags
Soft Saddlebag Luggage without Racks HanSolo DL650A - 2017+ 9 08-02-2018 05:22 PM
Soft Saddlebag Guards 2017+ DL650 and 2014+ DL1000 richlandrick AdventureTech LLC 3 03-26-2018 07:07 AM
Soft Saddlebag Guard richlandrick DL1000A - 2014-2016 92 05-29-2016 08:37 PM
Soft saddlebag Question surfrider General V-Strom Discussion 16 04-13-2016 09:42 AM
