LED Bar Light installation in DL650A - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 33 Old 11-04-2018, 01:27 AM Thread Starter
JAS
JAS's Avatar
Location: Cali (Valle del Cauca), Colombia - South America
Hi, I recently installed the Rigid Industries E-Mark 6" SR-Series LED Bar Light in my 2016 DL650A. It lights phenomenally and the range is really impressive, my only problem is that occasionally, in full dampers, the LED Bar reaches to strike the fender. If any of you have installed this type of LED bar lights on your V, I am very interested in knowing the type of support you used. Thanks and happy rides!!
vegashotwheeler likes this.
Juan Andres Sinisterra
2016 Suzuki V-Strom 650 ABS
2015 Yamaha MT-09 Tracer
2012 Suzuki V-Strom 650 ABS
2010 Suzuki GS 500
2009 Honda CBF 150 GP
JAS is offline
post #2 of 33 Old 11-04-2018, 02:51 AM
Gert's Avatar
Looks interesting. How much clearance would there be under suspension compression, if the LED strip was mounted to a fork brace, instead of under the cowling? Not sure of the vibration though.
Gert is offline
post #3 of 33 Old 11-04-2018, 08:41 AM Thread Starter
JAS
JAS's Avatar
You mean something like this? (see attachment). Well it would give me more clearance, but I'm thinking it would produce a shadow on the road, coming from the main lights when the LEDs are off, could that be possible?
On the other hand, it wouldn't look nice; it would look like something external to the fuselage of the bike's nose... Ugly! This would not matter to me at all; however the issue of the shadow would be what worries me more...
And there is also the thing about vibration you mentioned, because to be positioned that far the LEDs would need a metal arm, so the vibration would increase. That could be solved by using a thicker arm I think.
Next week I will take the bike back to the people who made the mounting thing. I went there yesterday and we were talking about a solution; the man says that the option would be to raise the light bar about an inch or something. That would pressure a bit the cowling (which is plastic anyway), to avoid having to cut it to make room for the light bar. And he also mentioned that we could adjust the front suspension to raise it a bit.
In any case, I guess the modification we're gonna do needs to give me about 1.5/2 inches of clearance.
I'm still scratching my head with this solution we are gonna do next week, we'll see there in the workshop if this works. But in the meantime I'm thinking about other solutions, and consulting with other riders to see if someone has invented a better mount than the one we already did.
Please excuse this loooong answer, I'm thinking out loud; this helps me find solutions, haha!!
Thanks Gert!!
2010 Suzuki GS 500
JAS is offline
post #4 of 33 Old 11-04-2018, 10:49 AM
Spec's Avatar
Me I would cut into the lower fairing to get it up under the headlight.
Carefully!
Spec is offline
post #5 of 33 Old 11-04-2018, 11:06 AM Thread Starter
JAS
JAS's Avatar
Yup, we are gonna try first by raising the LED box as far as possible, blending a bit the plastic of the fairing (by pressure). If that doesn't give us an acceptable result, then we would cut. CUT!!
That play cannot be undone, so... care would be a must!!
Thanx Spec!
2010 Suzuki GS 500
JAS is offline
post #6 of 33 Old 11-05-2018, 01:57 AM
Gert's Avatar
Your pix in post #3 is not correct. The fork brace is installed on top of the front fender, where the forks and fender meet. The light will follow the direction that the fork / wheel is pointing. No sure whether the LED strip is the same length as the width of the forks, nor how it would look once mounted on the fork brace or how much light it would cast when mounted lower.
Gert is offline
post #7 of 33 Old 11-06-2018, 03:53 PM Thread Starter
JAS
JAS's Avatar
Oh ok, I see. Well we considered that option too, however there is aomething to keep in mind and is the vibration... the wheel vibrates more than the bike so it is possible that the light beam would be bouncing on the road, which wouldn't be ideal. But it is an interesting solution anyway, thanks Gert!
2010 Suzuki GS 500
JAS is offline
post #8 of 33 Old 11-08-2018, 03:37 AM
Gert's Avatar
A weather strip rubber could help to dampen some of the possible vibration on the LED strip. Normally a vehicle LED strip should be able to handle more vibration abuse than the normal motorcycle globe would.
Gert is offline
post #9 of 33 Old 11-08-2018, 12:51 PM
Motor7's Avatar
I think the custom light bar you posted in #3 is the answer. However, if there is room under the nose to cut and tuck the lightbar in there I would not hesitate to do that.
Then you have to ask yourself how much brighter or eye-catching is the light bar over two separate lights and is it worth the mounting hassle?
15 DL650XT
Motor7 is offline
post #10 of 33 Old 11-08-2018, 01:36 PM Thread Starter
JAS
JAS's Avatar
Great appreciations Gert, thank you very much buddy!!
2010 Suzuki GS 500
JAS is offline
12 O'clock Labs Programmable Brake Light Flasher Module SV Racing Parts SV Racing Parts 1 03-03-2015 01:16 PM
Denali D4 Light Installation Photoryder Maintenance, Tech and Products. 3 02-19-2015 01:46 PM
LED Tail Light (No eBay links allowed) garandman V-Strom Modifications and Performance 47 06-12-2013 11:49 PM
