Idiot needs help..... rear axle removal '17 wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 18 Old 10-06-2018, 10:19 AM Thread Starter
Fynlcut's Avatar
Ok I'm getting frustrated....
Removed the axel nut from the left side (shift side)
Removed chain tensioner bolts.
Removed speed sensor
Remove brake caliper bolt.
Axel will slide for and aft just fine.
Axel head will not turn.
Axel will not move toward the required exit at all.
What am I missing?
Fynlcut is offline
post #2 of 18 Old 10-06-2018, 10:34 AM
Jim L's Avatar
Shouldn't have to remove the tensioner bolts, I wonder if it's just cockeyed and binding with those bolts removed.
Jim L is offline
post #3 of 18 Old 10-06-2018, 10:36 AM
My 2013 the nut is on the right (brake side). I have heard some turn them around and can't say if the 17 is different. Your chain is loose or off sprocket? Wack the axle with something softish or tap with something hardish? Weight of rear wheel is hanging on it so maybe little lift on the wheel. You do have the bike supported via center stand, stand or lift? kfh000
kfh000 is offline
post #4 of 18 Old 10-06-2018, 11:05 AM
You can put the nut back on the axle to protect the threads and whack that with a hammer.
I prefer to use a hard plastic mallet or a rubber mallet when getting serious with a item like the axle.
When you finally get it loose be sure to grease the axle before reinstalling. I've had them rust to the bearings before. It took a fair amount to coercion to break it loose.
VSrider and Gert like this.
post #5 of 18 Old 10-06-2018, 11:08 AM Thread Starter
Fynlcut's Avatar
I started with just the axel nut loose. Didn't make any progess.
Started removing bits and pieces as I went, thinking maybe I'm just stupid.
Rear wheel is off the ground. I've tried supporting it with my foot and whacking it with a 2lb dead blow hammer.
I'm hoping it will eventually break loose with continued application of wd40 and a the hammer.
Fynlcut is offline
post #6 of 18 Old 10-06-2018, 11:40 AM
RCinNC's Avatar
If you're going to spray a solvent in there, I'd probably set the bike back down on the side stand and spray the solvent in from the uphill side. Gravity will be your friend, and help the solvent penetrate further. I usually use PB Blaster when it comes to a stuck part, and if it's stuck this bad, I'd spray it and let it sit for an hour before I tried whacking it again; let the solvent do its work.
This wouldn't be the first time I've heard of an axle seizing to a wheel. I got in the habit of smearing my axles with anti seize before I reinstalled them.
RCinNC is online now
post #7 of 18 Old 10-06-2018, 12:07 PM
It won't turn with a wrench or ratchet? I'd try to break it loose this way first.
06 V-Strom DL650
John V Strom, Jr. is offline
post #8 of 18 Old 10-06-2018, 12:28 PM
My guess would also be a bearing that's somehow sticking to the axle. If you've given the axle enough room to move forwards and backwards (chain loose, chain adjusters all the way forward) it should just slide right out.
Like others said, some penetrating lubricant (WD-40 or similar) and/or lifting the wheel a bit so that there's no weight acting on the axle itself and/or some gentle persuasion with a large hammer should do the trick.
If you eventually get it loose but needed quite a bit of force to get it loose, make sure you inspect all three wheel bearings for damage. They should rotate with virtually zero resistance, and there should not be any lateral or axial play in them. (Note that there's three of them: Two on the wheel hub itself, and one on the sprocket carrier.)
And put some grease on the axle before reinstalling it.
BackPacker is online now
post #9 of 18 Old 10-06-2018, 12:43 PM Thread Starter
Fynlcut's Avatar
Took some effort to get it out. Celebrating now, but I'll inspect everything before I put it back together.
notacop and kfh000 like this.
Fynlcut is offline
post #10 of 18 Old 10-06-2018, 01:14 PM
What finally did the trick?
thirdofthree is offline
I think I'm going crazy ...please help with my rear axle caruser4 DL650 and DL650A - 2004 to 2011 34 12-21-2017 12:22 AM
Rear axle and sprocket misalignment? Copernicus DL650 and DL650A - 2004 to 2011 5 07-30-2014 10:59 AM
Rear axle install question Old Surf Dog DL650 and DL650A - 2004 to 2011 20 07-09-2014 03:59 PM
Rear Axle Nut Locking Methods / Issues ? Harry Dresden PI General V-Strom Discussion 9 02-08-2014 01:14 PM
