rear wheel speed sensor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By V-Tom
  • 1 Post By Motor7
post #1 of 7 Old 10-05-2018, 02:20 PM Thread Starter
Im going to be replacing my basically brand new tire because of a pin which decided to get stuck in it.
In the service manual it talks about removing the speed sensor, but before physically removing unplugging it. Is this absolutely necessary? Will it short or something?
2016 DL1000 ABS
ERockJL is offline
post #2 of 7 Old 10-05-2018, 02:44 PM
locoblanco's Avatar
Just have to unbolt it and let it hang out of the way, no need to disconnect anything electrical. Do this first, as there is very little clearance and you don't want to damage it.
locoblanco is offline
post #3 of 7 Old 10-05-2018, 03:38 PM Thread Starter
Thanks
Any idea why the manual would have you unplug the sensor first?
Edit: Actually nevermind, im sure the manual only has that for full sensor removal. For the tire, it just has to be out of the way
2016 DL1000 ABS
ERockJL is offline
post #4 of 7 Old 10-05-2018, 05:53 PM
blaustrom's Avatar
Have you considered plugging the tire or is the hole so big?
I have used Nealey with great success.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #5 of 7 Old 10-05-2018, 06:19 PM
larolco's Avatar
Yeah, it's just a rear. I'd try a plug first. At worst there will be a slow leak. Most likely though the plugged tire will be good for the remainder of its life. I once ran a rear tire with three plugs in it for most of its life (about 2 years for me). They held fine.
DRZ400SK17
larolco is offline
post #6 of 7 Old 10-05-2018, 06:55 PM
V-Tom's Avatar
I've plugged about 15 tires and had one plugged on my Boxster with no issue. I use the String type of plugs.
I don't see any reason you wouldn't plug yours unless the sidewall had the hole.
..Tom
Gert likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #7 of 7 Old 10-13-2018, 07:51 AM
Motor7's Avatar
If you do pull the rear, make sure the caliper bracket, which has two slots on the swingarm side of it, engages the square 3/4 x 3/4 block sticking out on the swingarm. This is a common mistake where the calpier bracket is installed above and out of the slot where it can rotate when braking....not good and it can snap off the ABS sensor. The slot allows the caliper to move forward or back with the rear wheel adjustment....photo in this thread:
https://www.stromtrooper.com/dl650-d...2Ahelp%2A.html
Gert likes this.
15 DL650XT
Motor7 is offline
Speed Sensor Replaced hobbyist DL650 and DL650A - 2004 to 2011 0 10-04-2018 01:51 AM
Rear wheel bent non ABS 07 what rear wheels fit? ukele6 DL650 and DL650A - 2004 to 2011 9 05-30-2017 02:25 PM
Speedometer Speed Sensor Noise vur DL650 and DL650A - 2004 to 2011 2 05-07-2016 10:53 PM
Rear wheel too wide for swingarms tshelfer Maintenance, Tech and Products. 31 08-15-2014 08:06 PM
Checking rear sprocket for wheel alignment Jproaster General V-Strom Discussion 17 05-17-2014 03:53 AM
