Engine replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 10-01-2018, 06:39 AM Thread Starter
Engine replacement
I have a 2002 DL1000 with 138k on it, I am thinking of fitting a 2009 DL1000 engine with only 30k on it. Will it work and what will be involved? Thanks from down under!
Gert Steyn is offline
post #2 of 11 Old 10-01-2018, 08:23 AM
As far as I know all the hard points are exactly the same. What you will get into is the electrical. Your 2002 has a different rotor and stator. You could swap them into the newer engine or research going to the later higher output rotor/stator to see what it takes to make it work. I know there are differences in the ECU between the two, so it would be easier to figure on swapping all sensors from the old engine onto the new. If they all go in the same place that should take care of that.
realshelby is offline
post #3 of 11 Old 10-01-2018, 08:56 AM Thread Starter
Thanks for the time and response mate.
post #4 of 11 Old 10-01-2018, 01:19 PM
Somewhere on this forum there's a story, or there are stories, of an older Vee with 400K+ miles on it. I think little, if anything, has been done to that engine (other than oil changes, plugs, probably valve checks / adjusts, etc.).
You mention mileage. Just thought I'd mention this well-documented, very high-mileage Vee, as a reason to not worry much about only 138 (kilometers? 86K miles?) on it.
Maybe there's another reason, or maybe you just like wrenching...
Good luck regardless.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 46K+. Love it!
HokiesRWee is offline
post #5 of 11 Old 10-01-2018, 01:28 PM
Lrobby99's Avatar
Great project to post here with pics!
You could get a lot of feedback/advice along the way.
Gert likes this.
Lrobby99 is offline
post #6 of 11 Old 10-01-2018, 03:11 PM
Pepe lopez's Avatar
138k? just getting broken in
2016 wee strom -- when in doubt, give it gas
2009 KLR 50k
2005 KLR 25k stolen
1982 XJ1100 200k miles and going, only oil and plugs
1976 XS750 special
1966 international pickup, Harley retrieval vehicle
Pepe lopez is offline
post #7 of 11 Old 10-02-2018, 06:08 AM Thread Starter
I surged for the post with the high mileage, my bad 😂. North of 300k miles and still going strong, that has to say something! I also found the posts about the clutch chudder and I reckon that’s the noise, not the gearbox. Classic louder with clutch released in neutral. I will do the brass spacer trick on the basket and see how we go. Absolutely love the bike and happy to do what ever it takes to keep it running smooth.
Big B likes this.
post #8 of 11 Old 10-02-2018, 02:28 PM
You may have idle hammer or the chudder or any other problem. Try www.werksparts.com Realshelby can help you confirm it. I am sure there are youtube videos. Seems like a big jump to a replacement engine before you diagnose exactly what the issue is. It runs and does not smoke/clank/leak? kfh000
kfh000 is offline
post #9 of 11 Old 10-02-2018, 04:11 PM
You can read WERA688 's posts here about his 2003 DL 1000 that has at my last contact 438,000 miles on it. That will give you a good idea of what does wear out and need replacement as the miles add up.
post #10 of 11 Old 10-02-2018, 04:18 PM
RCinNC's Avatar
I believe Wera actually retired the old war horse and got a Super Tenere....
RCinNC is online now
Replacing stock Adventure engine guards Mastery DL650A - 2012-2016 2 08-21-2017 05:30 PM
Engine swap, putting a DL1000 engine back in CruisnGrrl DL1000 from 2002-2012 12 03-11-2015 10:45 PM
Engine Help! Got Broken Magnets Throughout My Engine! Pooky DL1000 from 2002-2012 31 02-13-2014 06:04 PM
