09 won't start (videos links included) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By Brockie
  • 3 Post By sfalexi
post #1 of 8 Old 09-16-2018, 11:50 PM Thread Starter
Turn key on, mysterious clicking and the clicking changes when I hit the engine cutoff switch. Battery is fine and was freshly trickle charged. Voltage seems correct. I've checked the little plug connecting the clutch lever and the little plug on the other side connecting the engine kill switch.
I would LOVE to ride. But can't.
It started after it was left out in a heavy rainstorm. I rode to the gym, and while I worked out there was a VERY heavy rainstorm. It didn't start so I had my wife pick me up, I brought the battery home and charged it, and the next day picked it up and rode home. Two days later went to turn it on and it clicked and the display went out.
So I thought it was the battery again. Brought it in to trickle charge it (it went "green" almost right away), went away for a few weeks, came back and this evening reinstalled it to see if it would work.
I have no idea what it could be, and I live in an apartment complex which limits what I can and cannot do, but I've had some plastics off in the parking garage and haven't been yelled at yet. But I've got limited space and access to bring tools out there. Anything I can easily try?
Please help if you can.
Alexi
sfalexi is offline
post #2 of 8 Old 09-17-2018, 12:26 AM
Sorry, but I think it could still be your battery. If you could try getting a jump start from another vehicle via jumper cables, that should help confirm if your battery is/isn't the culprit.
If it still doesn't start after trying the jump start than get back to us for other logical suggestions.
Good luck!
gdrew is offline
post #3 of 8 Old 09-17-2018, 01:01 AM
blaustrom's Avatar
You need to measure battery voltage before and during staring attempts.
My guess is that the battery is dead but without data it's just a guess.
Also if it got very wet, there are drain holes around the spark plugs to allow water to run off. They tend to clog up. Make sure that they are fee and that there is no standing water around your spark plugs.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #4 of 8 Old 09-17-2018, 10:59 AM
With the voltage drop indicated on your meter, it looks like dead battery time. Undo the battery terminals and hook the car battery to the wires and give it a try.
Just don't have the car running when doing it.
post #5 of 8 Old 09-17-2018, 11:11 AM
Brockie's Avatar
Thumbs down
Dead battery. With key on both needles should go to max and then return to zero. They do not. Also you need a stable 12.8 volts. The difference between starting, and a click, is just part of a volt. You have a dead cell in there.
Big B likes this.
Brockie is online now
post #6 of 8 Old 09-17-2018, 11:40 AM
DonOhio45813's Avatar
I agree on the bad battery. And for future reference, trickle charging a low battery is a waste of time, use a real charger.
DonOhio45813 is offline
post #7 of 8 Old 09-17-2018, 12:50 PM
blaustrom's Avatar
Just looked at the videos. Get a battery AND a smart charger like the battery tender. A trickle charger ruins the battery over time.
Blau2 2014 DL1000A
post #8 of 8 Old 09-17-2018, 04:14 PM Thread Starter
Took out the battery and connected my car battery directly to the wires from the bike. Bike started right up. :mad:
I'll be purchasing a new battery today and I have already purchased a solution to the parking garage problem (it arrived last week as this isn't the first time I haven't been able to ride for a few weeks and found battery not able to start the bike). I'm installing it today.
I don't have a garage to put a battery tender on, so I purchased a small 2.5 watt solar battery maintainer designed to maintain boat/rv batteries (weather proof intended to be on there to keep a battery topped off) and will be installing it and parking my bike by some sunlight in the garage (around the edges or top level of said garage). Man I hate not having a garage.
Alexi
notacop, VSrider and Brockie like this.
sfalexi is offline
How the start switch starts the engine and disconnects the headlights greywolf Maintenance, Tech and Products. 10 03-11-2019 08:31 PM
OK Please help im in a tough spot. Bike wont start. Redline Maintenance, Tech and Products. 2 09-01-2015 11:06 PM
Clip Master Links for Drive Chain Indianaboyd V-Strom Service and Maintenance Questions and Discussions 17 08-19-2011 05:31 PM
lowering links installation stevet General V-Strom Discussion 12 04-04-2008 10:28 PM
