08 650 Won't Start - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By notacop
  • 2 Post By Rolex
  • 1 Post By Gert
post #1 of 6 Old 09-15-2018, 03:30 PM Thread Starter
Unhappy 08 650 Won't Start
Hi guys,
I was out for a beautiful ride, stopped for gas, went to start up and... no go. With ignition on, I get instrument sweep, fuel priming, but no headlights and start button does nothing.
Have checked clutch switch, side stand switch, took apart start switch and cleaned contacts. No luck.
Any thoughts? Which fuse(s) to check first??
Thanks,
Rob
HillyAir2 is offline
post #2 of 6 Old 09-15-2018, 07:12 PM
I did that to myself once, it was the kill switch. I never intentionally use that switch and it took me a while to see it. I think it gives a CHEC light on the dash.
madstrom likes this.
post #3 of 6 Old 09-16-2018, 04:09 PM
Rolex's Avatar
Could be the start switch contacts or the big connector on the left side.
No headlights is the clue.
It is not a safety switch & the kickstand switch only plays a part if the bike thinks it is in gear, if you have a neutral light forget the kickstand switch as being the problem.
If the bike starts but stalls every time you select a gear it is the kickstand switch.
blaustrom and Fox like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 6 Old 09-21-2018, 01:16 PM
On my 09 sometimes the connector to the clutch lever switch fall out, or are poorly connected. It is black ad sits about 2-23 inches inside from the clutch lever, on the handlebar.
~CW
croissant_warrior is offline
post #5 of 6 Old 09-21-2018, 09:05 PM
Rolex's Avatar
~CW
Yes that is very common but it will not stop the headlights working.
2014 V2, Snoopy
Rolex is offline
post #6 of 6 Old 09-29-2018, 08:08 AM
Gert's Avatar
@HillyAir2 (Rob), have you managed to solve the starting problem on your K8 Wee? If so, what did you find to be the problem?
notacop likes this.
Gert is offline
Engine won't start, FI light comes on R-2 DL1000A - 2014-2016 49 07-08-2015 01:21 PM
CHK light and no start FLS DL650 and DL650A - 2004 to 2011 3 05-22-2014 02:13 PM
Hard to start, befuddeling Rogue Reaper V-Strom Service and Maintenance Questions and Discussions 4 11-22-2013 12:19 AM
2005 V-strom 650 won't start skiphunt DL650 and DL650A - 2004 to 2011 12 05-23-2010 09:35 PM
Help-wouldn't start before big trip Peterbob V-Strom Service and Maintenance Questions and Discussions 6 06-14-2008 03:21 PM
