FI error on first start up after valve clearance check - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By dmfdmf
  • 3 Post By KSM
post #1 of 7 Old 07-12-2018, 12:55 AM Thread Starter
KSM
KSM's Avatar
2012 DL650A - 16,800 miles. I did my first valve clearance check (everything in spec). On first start up I get FI error (red FI light illuminated and FI displayed alternating with odometer readout). I've just read a bit about dealer mode and getting a specific code. I have not yet done that. In the meantime, any suggestions? Thanks.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #2 of 7 Old 07-12-2018, 01:06 AM
dmfdmf's Avatar
Double check all the wires and hoses that plug into the airbox, most common place for error on reassembly.
Motor7 likes this.
Next Up: ?
dmfdmf is offline
post #3 of 7 Old 07-12-2018, 01:46 AM Thread Starter
KSM
KSM's Avatar
Good call, I did miss a hose going into (or adjacent to) the airbox. Started up and I still get the FI error. Disconnected the battery hoping to clear the code but I still get it.
KSM is offline
post #4 of 7 Old 07-12-2018, 03:13 AM
Gert's Avatar
What dealer mode code do you get on the display? The code will give a guide as to what the bike / ECU is not happy with.
Gert is offline
post #5 of 7 Old 07-12-2018, 08:16 AM
Motor7's Avatar
Does it idle and run up ok??
Valves out of spec will not throw a check engine light so something did not get plugged back in, or you crossed wires or vac tubes. Did you unbolt the the whole front cowling and move it up and out of the way like I did? If so, something might have come unplugged going to the instrument panel.
There is a vacuum line that goes to the gas tank, and it usually falls down into the nest of wires and tubing....make sure it is on.
Read this thread, put it into dealer mode, then read the error code:
https://www.vstrom.info/Smf/index.php/topic,7061.0.html
Just a WAG, but I wonder if the engine coolant sensor did not get plugged back in when moving the radiator?
15 DL650XT
Motor7 is online now
post #6 of 7 Old 07-12-2018, 02:47 PM Thread Starter
KSM
KSM's Avatar
Dealer mode indicates C13 - IAPS Double checking the harnesses and hose around there.
KSM is offline
post #7 of 7 Old 07-12-2018, 03:20 PM Thread Starter
KSM
KSM's Avatar
Got it sorted out. I had missed both of the hoses associated with IAPS. Took me two tries to realize I hadn't reconnected ether. Solved the error code immediately. Thanks!
Gert, Motor7 and wingstrom like this.
KSM is offline
