Chain making a bunch of noise? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 27 Old 07-11-2018, 10:50 PM Thread Starter
Question Chain making a bunch of noise?
I've got a 2004 V-Strom 650 at 25k miles and my chain makes a clunking sound. I know little to nothing about motorcycles. The guy I purchased it from a few years ago mentioned needing to lubricate the chain on dirt roads. Recently I started living down a mile dirt road. It's always made the sound but if I lubricate the chain it goes away or dies down for a while. Being on this dirt road I'm having to lube my chain bi-weekly. Is this normal or is my chain somehow loose? It makes the clunking sound usually in lower gears at lower RPMs, so like if I am pulling a hill or if I don't shift down and just release my clutch slowly while throttling. I haven't noticed any performance issues, just sounds very loud at times.
Thanks!
There is a solution to every problem and good in every day. You only fail when you stop trying, either win or learn.
silvercobra is offline
post #2 of 27 Old 07-11-2018, 10:55 PM
teevee's Avatar
time for new chain and sprockets while you're at it
'08 DR650, '07 DL1000
teevee is offline
post #3 of 27 Old 07-11-2018, 11:54 PM
BC Rider's Avatar
Grab your chain in the middle and move it up and down. How much slack do you have. If over an inch and a quarter center to center you need to adjust your chain. look here https://www.v-strom.co.uk/downloads/...nersManual.pdf
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 27 Old 07-12-2018, 01:39 AM
OydnaR's Avatar
chains need lube regardless of road surface, paved or gravel
madstrom, VSrider, K9 Wee and 1 others like this.
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #5 of 27 Old 07-12-2018, 10:42 PM Thread Starter
I can move the chain about 4 inches up and down. So it needs to be replaced or tightened? I can have them do it on my next oil change maybe?
post #6 of 27 Old 07-12-2018, 10:52 PM
teevee's Avatar
definitely tightened but likely due for replacement. i understand the expense but if it snaps it could puncture the engine case and perhaps your left leg
WildDoktor likes this.
teevee is offline
post #7 of 27 Old 07-13-2018, 12:15 AM
kiwi_outdoors's Avatar
fix it now
tighten it now and go shopping for new chain and sprocket to do the real fix ASAP
tightening a chain is easy.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #8 of 27 Old 07-13-2018, 01:36 AM
WildDoktor's Avatar
A broken chain has made my life pretty miserable these last 7 months. Have a read here. But before you read it, adjust your chain and order a new one plus sprockets.
WildDoktor is online now
post #9 of 27 Old 07-13-2018, 03:52 AM
BC Rider's Avatar
At 4 in slack that chain is slapping around and is close to jumping off. Do a chain adjustment as it is something you need to learn to do. When you have a new chain and sprockets it will need to be adjusted a few times as it wears in a bit. Then just once in a while for most of it's life. At the end of its life it will need more frequent adjustment again. Once adjusted properly you will be surprised by how much smoother the ride will be with no slop in the drive train. oh, and yes, oil it, there is a thread somewhere with a hundred different opinions on chain oiling.
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #10 of 27 Old 07-13-2018, 11:22 AM
Stop riding your bike until the chain and sprockets are replaced.........
madstrom, chicago, Motor7 and 1 others like this.
