FI Error C17 (2015 DL1000A) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By Zaphod
  • 1 Post By Hatchi
  • 1 Post By Zaphod
post #1 of 4 Old 07-11-2018, 02:07 AM Thread Starter
Zaphod's Avatar
Long-time lurker, first time poster.
I've just resolved a problem with my bike which I wanted to share to help anyone who might suffer similar symptoms. The bike was bought new in 2015 and has just over 50k km on the clock.
The bike started showing a FI light warning after riding about 20km. When the ignition was cycled it would start normally and the warning would disappear for a short period before reappearing. Sometimes the engine would behave normally after the restart, other times throttle response would become very choppy - riding at 30-40km/h in peak-hour traffic became a nightmare but highway speeds were fine.
In dealer mode it showed the error code C17 (Intake Air Pressure Sensor).
After much frustration checking connections etc I eventually removed the vacuum hose that runs from the throttle body to the sensor (Suzuki Part # 13683-48G10).
At the bend in the hose where it joins to the throttle body, the hose had what looked like a bubble in the rubber and was very soft - a bit like a bruise on an apple. I cut it open and the inside lining had perished and almost gooey. My guess is once the engine temp heated it up the vacuum would collapse the hose, blocking it.
Since replacing it with some vacuum hose I had lying around, the error is no longer showing up and the throttle response is much smoother.
I hope this helps someone avoid the headaches this caused me.
pvwheeler and Gert like this.
Zaphod is offline
post #2 of 4 Old 07-11-2018, 10:58 AM
That's really interesting. I've not read that failure mode before. Also surprising that it occured on a 3 year old moto. Do you have any pics off the damaged cross sections?
Gert likes this.
Hatchi is offline
post #3 of 4 Old 07-18-2018, 08:27 PM Thread Starter
Zaphod's Avatar
Here's a couple of pics of the piece of tube I cut.
The first two shows were the 'bubble' was. The last one is the end that connected to the throttle body to show the difference.
Hatchi likes this.
Zaphod is offline
post #4 of 4 Old 07-18-2018, 10:37 PM
Thanks for sharing, good check for others to do.
Hatchi is offline
