URGENT HELP - SWITCH RACKS OEM to OEM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By BC Rider
post #1 of 5 Old 06-20-2018, 02:04 AM Thread Starter
ommoran's Avatar
Exclamation URGENT HELP - SWITCH RACKS OEM to OEM
Hi all,
Had an accident with my 2011 DL650A, which meant the bike was a write-off. I kept the Trax boxes and the racks.
My new bike, a 2011 DL650, came with the plastic side cases and top box. Different mounting bracket.
I CANNOT GET THE OLD BRACKETS OFF!!! I have managed to loosen 2 screws, but the other 4 are stubborn bastards and I'm worried that I'm stripping the hex head with my allen keys.
Can someone please give me some advice? I have no idea how they were attached - previous owner, dealer, etc. I don't believe they used any thread fastener. Any suggestions on how to move these?
Of course, I leave on a [email protected]#$#[email protected]%!#$)!%$# trip tomorrow. I thought this, if anything, would be easy.
2011 Wee-strom and loving it.
ommoran is offline
post #2 of 5 Old 06-20-2018, 02:14 AM
BC Rider's Avatar
If it is a factory install there may be thread fastener goop on it. A gun style soldering iron is great to heat the fastener up. Even if there is no goop a few heat/ cool cycles and penetrating lube will help.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #3 of 5 Old 06-20-2018, 02:17 AM
If the head sits proud, giving it a sharp hit with a hammer can sometimes help - if you are sure there is no thread lock installed (otherwise heat as advised is the go).
If you do strip the head, then drill the head off, and use new bolts on the new bike.
Snapback is offline
post #4 of 5 Old 06-20-2018, 02:39 AM
BC Rider's Avatar
Another method to break them free is to use a cordless impact(dewalt, Milwaukee etc). But be cautioned that it can also rip heads off of small bolts. The many small impacts help break it loose. Little blast of tighten then reverse. Tighten, reverse. Take your time. I find less chance of stripping out compared to allen key.
wingstrom likes this.
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #5 of 5 Old 06-20-2018, 07:46 AM
bighammer's Avatar
Drill slowly and remove the heads if/when all else fails.
2018 Flee-Strom 1000XT
bighammer is offline
