Rotopax gas cans, yet again (Vee) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 12 Old 06-18-2018, 09:28 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
I've pretty much settled on some size of Rotopax gas can to take extra fuel on my more remote rides.
The questions are, which size, and where am I going to mount the thing?
The 1 gallon Rotopax cans are compact, but one gallon isn't much extra range on a Vee (~30 miles worst case). Also, the 1.75 gallon and larger cans are much better buys in terms of $-per-fuel volume.
I suspect the 2 gallon can would be just a bit too big & heavy.
I'm not too sure where I would mount it. I have a Kappa K48 top case and Givi E36 side cases. These don't have any flat surfaces or good attachment points, so using the actual Rotopax mount is not going to happen. Rok straps should work if I leave behind a side case, though I'd rather not as the whole point is to have a "get to the next gas stop" reserve for road trips.
I measured, & it's not going to fit laying flat on the "passenger" area of the seat, either (that goes for both 1.75 and 2 gallon sizes).
If I have all my luggage on, I'm pretty much stuck using Rok straps (or rope or what have you) to stick the Rotopax on the outside of a side case.
Has anyone tackled this problem lately? How did you end up mounting the thing with luggage on?
DesertBike is online now
post #2 of 12 Old 06-18-2018, 10:30 PM
Hard miles's Avatar
Remove the top case and use bags instead to carry the top case stuff. Plenty of room then. I only use my top case while riding with friends ( 500 km day trips). On long (multi day) trips I ditch it for more packing room. I keep my hard luggage on (panniers).
You can also do like some & fix it to the outside of your crash bars - this is not advisable due to possible crashes.
A Canadian gallon is about 10 lbs - less for American. You don't want too much weight on top of your seat (high center of gravity)
Brian
Hard miles is offline
post #3 of 12 Old 06-19-2018, 12:47 AM
Hard miles may be right about high weight loads. I have a Kolpin mount on top of my oversized top box but haven't tried riding with it mounted. I've ridden until the low gas light has lit and still had a gallon left when I finally found a gas station to fill up. Just the thought of having an extra gob of fuel is comforting.
DesertBike likes this.
notacop is online now
post #4 of 12 Old 06-19-2018, 06:58 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
I really don't want to not have a top case, or have additional weight up high, if it can be helped. Top case is where I park my helmet & it mounts an LED brake light/turn signal bar. Could do without it if I absolutely had to, but I like having a "trunk" that won't dump its contents when opened (like the side cases tend to do).
The 1.75 gal Rotopax lists at 3.4 lb so with it full (@ 6.0 lb per US gallon for gas) you're up near 15 lb.
For the 2 gal Rotopax it's 3.8 lb empty, so 12 lb. of gas for closer to 16 lb total.
I'm not a fan of putting a Rotopax on the crash bars either. I generally don't drop the bike any more, but when it inevitably happens, I don't especially want to add a busted gas can + gas everywhere to the mix.
post #5 of 12 Old 06-19-2018, 08:54 PM
Hard miles's Avatar
Another option is to buy another type of fuel container (those small 1 gallon red containers) and put it inside your hard lugage. I attach mine to the back seat in front of my gear - tied on with strap & cargo net.
Pasted a photo from my Canada tour.
post #6 of 12 Old 06-19-2018, 08:59 PM
Hard miles's Avatar
Another option is to buy another type of fuel container (those small 1 gallon red containers) and put it inside your hard luggage. I attach mine to the back seat in front of my gear - tied on with strap & cargo net.
Pasted a photo from my Canada tour (2nd attempt).
post #7 of 12 Old 06-19-2018, 09:07 PM
Brickmouse13's Avatar
Perhaps you could remove the windscreen and affix them there?
Or a better option might be to strap them to the tank like a tank bag?
Where there is a will.....
Brickmouse13 is offline
post #8 of 12 Old 06-19-2018, 10:18 PM
i did what Hard miles suggested for a while with my 800ST BMW. Never needed it and after a few tours I stopped bringing it along. I put mine in a tool satchel that hid the gas can look to the casual thief.
I'm not sure I'd notice the extra weight on the top box. When out riding where I'd need the fuel I'm not playing racer boy and it might be a moot point.
There are mounts for the passenger pegs that hold some standard gas cans. Another option to consider.
post #9 of 12 Old 06-19-2018, 10:33 PM
Stalky Tracker's Avatar
Following up on what notacop said, Pegpackers from Bestrest Products might be a solution.
https://bestrestproducts.com/product...ory/pegpacker/
YMMV
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is online now
post #10 of 12 Old 06-20-2018, 08:29 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Pegpackers are interesting, but I wasn't planning to spend that much. Puts the kibosh on taking someone with me, too.
Guess I'll have to buy a rotopax and see if I can make it work.
2007 Vee with too many farkles
