Handlebar USB and voltmeter with on/off - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 12 Old 05-06-2018, 04:16 PM Thread Starter
Macdoc's Avatar
This seems to hit all the buttons
Has an off switch that looks to be nicely protected.
Dual USB out and a Voltmeter. After two stator failures last summer a Voltmeter was on the must have list as an early warning.
Handlebar mount too.
I don't need the 12 V socket but might come in handy for a small compressor and the unit is fused. cable was long enough with some to spare. Like that type of open connector so did not have to take the battery bolts out to connect.
Came with 4 handy tie wraps for the cabling. Getting the handlebar mount on was fiddly ....the unit clips on and off the handlebar mount.......you need 3 hands to compress the clip and then get the screw ( finger screw ) lined up. Will have to check
https://www.amazon.ca/BlueFire-Water...andlebar&psc=1
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR65093 ST1100 sold
Macdoc is offline
post #2 of 12 Old 05-06-2018, 04:53 PM
Be aware of parasitic drain.......if on un-switched circuit.
notacop likes this.
post #3 of 12 Old 05-06-2018, 05:07 PM
The backlit switch seems awfully bright. Have you ridden at night yet?
BackPacker is offline
post #4 of 12 Old 05-07-2018, 08:52 AM
Also Ran's Avatar
I wasn't sure about all the lights and gauges so I opted for the bare bones, no lights or switches. I've hooked it up and left it to see if I get any drain which it doesn't seem to. It's an incomplete circuit till you plug something in right? So unless I forget I'm charging something I should do ok. Thinking I may get a volt meter to check the voltage on occasion. Kinda like this one.
USB Car Charger With Voltmeter - Dual Port 3A
"There's a Grey blur and a Green blur. I try to stay on the grey one." Joey Dunlop
Also Ran is offline
post #5 of 12 Old 05-07-2018, 09:39 AM
A 12V cigarette lighter doesn't have any parasite drain whatsoever, but a 5V USB does. How big the drain is, depends on the quality of the internal circuits.
I tested my el cheapo 12V to 5V converter for a cigarette lighter socket, and that one will drain the battery in about a months time.
post #6 of 12 Old 05-07-2018, 10:47 AM
Nice to see it comes with ceramic pad cigarette butts. Lol.
I have a similar one on the Gixxus, wired to a switched circuit on the fuse block.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #7 of 12 Old 05-07-2018, 12:49 PM
Yup which is why I mentioned that, I've heard of some draining in less than a week.
post #8 of 12 Old 05-07-2018, 10:39 PM
Rolex's Avatar
My testing tells me quality USB ports have a drain because of the way they drop the voltage from 12v to 5v.
The elcheapo ones have no drain.
My Zumo cradle has a 0.02amp draw so it would take a long time to drain down a healthy battery.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #9 of 12 Old 05-08-2018, 03:39 AM
The cheap ones may have no drain when not in use but can potentially heat up in use or if you have a funky electrical system they may result in your charger/device not doing so good.
The best option long term is to buy a decent one which should use less power (when in use) and then wire it up properly.
Rolex likes this.
rambaldi is offline
post #10 of 12 Old 05-14-2018, 09:16 PM
bwringer's Avatar
My shameful brain can and will forget to turn the switch off, so the charger/accessory circuit on all my bikes is powered by a relay. That way, I get full voltage and it shuts off automagically.
Also, if you plan to run an air pump through one of these circuits, install a bigger fuse. 10 amps will blow sometimes, 15 should be OK and still plenty safe if you get a short.
That particular gadget seems ridiculously large, and the lights would be distracting, but I guess that's a matter of personal taste. There are lots of neat USB charging widgets on Amazon and Fleabay.
bwringer is offline
