Happy Trails aluminum pannier repair - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Scott_J
  • 1 Post By Stalky Tracker
  • 1 Post By Ride2day!!
post #1 of 6 Old 05-03-2018, 05:55 PM Thread Starter
robertyknwt's Avatar
I am a klutz. This is where I park at work. This morning, riding up to where I'd back up to that spot, I got too close to the fence and my right-side Happy Trail aluminum pannier hit the edge of that fence. Derp.
The damage was that the nut on one bolt was "ripped through" the aluminum, and the nut on the other bolt was "partly ripped through". (Picture) I've got a plan for repairing it myself, but I have a question on one step of the plan:
  1. Using a couple of wood blocks and a hammer, hammer things flat where those holes are.
  2. Get a sheet of aluminum big enough to cover both holes with a lot of margin. (The holes are about 4" apart, so I'm thinking have a 2" margin all around by getting a sheet that's about 4" x 8".)
  3. Attach the sheet to the inside of the pannier. This is where I have a question: How?
  4. Drill new holes through the sheet where the old holes are.
So what would be the best way to attach that new aluminum sheet? I'm thinking maybe pop rivets, one on each corner and one in the middle of each long side. But I Know Nothing in this area, so I welcome any better suggestions. Thank you all for being here!
2011 V-Strom DL650 - Canadian in Tarzana CA
Previous: 1994 Yamaha Virago XV535
robertyknwt is offline
post #2 of 6 Old 05-03-2018, 06:41 PM
Epoxy with good surface prep.
robertyknwt likes this.
Scott_J is offline
post #3 of 6 Old 05-03-2018, 08:17 PM
Stalky Tracker's Avatar
JB Weld. I'd skip the metal plate and fill the hole with JB Weld and then spread it out in a thin layer on the inside.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 6 Old 05-03-2018, 09:39 PM
what Stalky said. just b sure to prep the area
Mulewright likes this.
Robert CB Schmaltz
14 Vstrom 1000
09 Connie
14 Versys 650
13 KLR
14 CRF 250 L
05 Shadow 1100
08 WR 250
05 Vrod
75 Z900 Kaw
Ride2day!! is offline
post #5 of 6 Old 05-04-2018, 04:02 PM Thread Starter
I confess, I've never used JB Weld for anything. I'd be a bit nervous to use it alone. Luckily, I found a place here in the L.A. area who'll cut me (or anyone) a sheet of 0.050" aluminum to my specs for $5-6. So I'll do that with the JB Weld. For prep, I saw that sanding and acetone are recommended for Al.
Question: "Regular" JB Weld? There are a few different varieties out there; so regular's OK on Al, or should I get a different flavour?
post #6 of 6 Old 05-04-2018, 11:16 PM
I use it quite a bit. I have 30+ year old wheel barrow with a plasitc bucket that is probably 80% JB Weld now.
I'd use regular. It has a longer setup time (more time to work with it) and a longer cure time (gotta wait). In your application I don't think it would matter, the adhesion for both is the same.
1974 Suzuki TM-250
1965 Suzuki 80
