OEM (I believe) center stand bolt missing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By drmonbowen
post #1 of 5 Old 04-29-2018, 11:41 PM Thread Starter
drmonbowen's Avatar
This is the left side mount for the (presumed to be OEM) center stand for my 650 (2010, but to most of the world: 2009). The circle shows my area of concern! I can't find the spec for this bolt anywhere, and I'd greatly appreciate any knowledge that you might be able to share...
advTHANKSance!
drmonbowen is offline
post #2 of 5 Old 04-30-2018, 12:24 AM
you are definitely missing one compared to my 2013. There should be one on the other side if like mine. I see blue loctite in your future. kfh000
kfh000 is offline
post #3 of 5 Old 04-30-2018, 12:38 AM
Brockie's Avatar
Remove the same one off the other side and take it to the shops for a replacement.
Brockie is offline
post #4 of 5 Old 04-30-2018, 11:33 AM Thread Starter
drmonbowen's Avatar
Definitely locktite, and pulling the other bolt makes good sense. Thank you both!
Brockie likes this.
post #5 of 5 Old 05-01-2018, 10:37 PM
Stalky Tracker's Avatar
If it is an OEM center stand I believe the left and right bolts are different lengths for that position, at least they are on my K6 Wee. The left side top (sitting on the bike) is M8 35mm and the right is M8 45mm. Ditto for the lower pair too, only they M10s.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
