Replacing the clutch push rod and oil seal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By locoblanco
post #1 of 6 Old 04-02-2018, 12:46 AM Thread Starter
Scorch's Avatar
Arrow Replacing the clutch push rod and oil seal
So, the clutch pushrod broke, part #15
https://cdn1.bikebandit-images.com/s...0408012008.gif
So I will replace it, and I would like to replace the oil seal, part #23
Any suggestion on how to get the old seal out and the new seal in without damaging it? I'm guessing some of you have done this before.
2008 Suzuki V-Strom 650: 69,000 miles as of Aug 2018 + 2018 V-Strom 1000ABS
www.suzuki2strokes.com/forum/
Scorch is offline
post #2 of 6 Old 04-02-2018, 01:32 AM
You can use a hook tool and pull it out, use a mini-lady's foot prybar and pry it out from the center, or using an ice-pick tool punch a small hole in the area of the seal between the outer sealing lip and the side wall. Screw a small sheet metal scre into the hole 2 threads and pull the seal out with a pair of pliers or a wire cutter. Install with a socket just slightly small than the outside diameter of the new seal, and using an extension, tap the seal in with a small hammer. Lubricate the inner sealing lip, but not the outer diameter of the seal. You could also place the old seal in front of the new seal to prevent damage to the new seal before you tap it in.
MAZ4ME is offline
post #3 of 6 Old 04-02-2018, 06:36 AM
Motor7's Avatar
The sprocket area thread - leak fixes & rebuilds!
15 DL650XT
Motor7 is offline
post #4 of 6 Old 04-02-2018, 09:33 AM
locoblanco's Avatar
My 07 SV had the same setup. There is a plate which covers the seal area, and I was able to remove only the rear and bottom bolts, pull the plate out from the bottom just enough to get my thumb up inside, and push the new seal into place. (The front bolt on that plate was partly hidden by the alternator cover, and I was looking for a shortcut.) Removed the old seal with a hook, it wasn't too tight.
Downs likes this.
locoblanco is offline
post #5 of 6 Old 04-02-2018, 09:40 PM
Downs's Avatar
^^^That's what I did. Bent the retainer plate out a little bit to get my right angle scribe in the seal popped it out and the new one in pushed in easy. Bent the retaining plate back and bolted it back together. I replaced my countershaft seal at the same time I was in there because it was a little leaky as well.
2004 DL650 "HMMVStrom"
1978 Suzuki GS1000 "Tennessee Hillbilly"
1982 Suzuki GS850G "Barnfind"
2008 MazdaSpeed 3
https://www.youtube.com/channel/UC8AHz-9CXcxNi5WlDOtYhPA
My channel ^^^
Downs is offline
post #6 of 6 Old 04-02-2018, 10:56 PM
That one semi hidden 10mm is a bitch! I ground down a 1/4" 10mm socket to fit, can't think of anything else that would work.
As far as the seal itself, easy peasy. Just insert the pushrod barely into the seal use it as a lever to pop it out. It's held in with almost zero pressure, doesn't take much. Put some oil on the new one and push it in with your fingers.
Current: '15 Tenere ES - 30k km
Past : '06 FZ6 - 115k km, '06 KTM 625 SMC - 30k km, '06 V-Strom 650 - 80k km, '07 FZ1 - 70k km
“Instant information is instantly obsolete. Only the most banal ideas can successfully cross great distances at the speed of light. And anything that travels very far very fast is scarcely worth transporting, especially the tourist.” - Ted Simon, Jupiter's Travels
regder is online now
