Valve Clatter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By MAZ4ME
post #1 of 5 Old 03-17-2018, 10:26 PM Thread Starter
Waltamatic's Avatar
Valve Clatter
Last December My FI light came on when I was leaving the house for a short ride. I narrowed the problem down to the Oxygen Sensor. Being short of ready cash (It was December after all) I promptly did a Google search, bought some resistors and bypassed that rascal. A quick trip around the block showed problem solved. Parked it back up ready for the next ride.
That next ride was today. Battery was dead.
I replaced the battery and cranked it up. It ran a little rough at first but settled down to a nice smooth familiar purr after a few minutes. Everything is good except, when I "get on it" the valves clatter like crazy. I'm not talkin a rattle here but a "loud A" clatter. My thoughts are that the clatter is due to the FI resetting, reading the OS bypass and coming up with some crazy fueling nonsense. If that is the case a new OS should fix my issue. Am I on the rite track or should I be looking elsewhere?
I would be super grateful for any insight that anyone can give.
If you keep doing what your doing your gonna keep getting what your getting.....
Waltamatic is offline
post #2 of 5 Old 03-17-2018, 10:43 PM
Hello!
You sure youre hearing valve clatter and not old gas causing spark knock under load?
Valves dont react to load, but you say when you "got on it" the clatter started. From your description of symptoms, for how long it's been since last run, I suspect a fuel issue.
Realize also that on 02 sensor is a "camera" of the engine control system. A too rich or too lean mixture can cause an 02 code to be set. The days of "Get a code, get a part" are a thing of the past. The code point toward the system, not the actual failure point.
Motor7 likes this.
MAZ4ME is offline
post #3 of 5 Old 03-18-2018, 07:45 PM Thread Starter
Waltamatic's Avatar
Well Sir, that just makes too much sense.
I've siphoned the tank as dry as possible today and will give it a couple gallons of premium tomorrow and see if that helps.
Thanks!!
post #4 of 5 Old 03-23-2018, 10:36 PM Thread Starter
Waltamatic's Avatar
Quick update.
I replaced the fuel in the tank and it's running like a top.
Problem solved.
Thanks!
post #5 of 5 Old 03-23-2018, 11:47 PM
Glad to lend a hand!
MAZ4ME is offline
