Ignition issues - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 02-22-2018, 09:52 PM Thread Starter
Lobojoe69's Avatar
Ignition issues
My key fits in ignition but wont turn the handle bars are locked and wont disingauge let alone turn on. Ive sprayed WD40 in the ignition but still does not turn key
Lobojoe69 is offline
post #2 of 3 Old 02-22-2018, 10:11 PM
Did you try jiggling the bars back and forth while turning the key? There might just be pressure on the locking pin not allowing the key to turn.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #3 of 3 Old 02-23-2018, 01:10 PM
larolco's Avatar
Same thing that can happen with a car's steering wheel lock. Pull the bars all the way to the left and the key should turn. Also, make sure you are applying downward pressure on the key.
You can also try inserting the key the opposite way, or use a backup key (original may be getting worn if it's old).
DRZ400SK17
larolco is online now
