tying in ignition to remote alarm - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-17-2016, 03:24 AM Thread Starter
Location: Kind of live in bc, but back to Nomad. No home.
I had decided to get rid of my ignition because of two reasons. A. New headlight literally needed the space and the 25 dollar key was a real piss off. I had added the spy 5000 to the bike. Cut whole ignition right out and relayed the 5 wires together. The brown and... geez. Green with yellow as one relay and the remaining red orange and orange with Yellow as another relay with of course the 100 ohm resistor so the ecm would turn on. All works as expected with a switch under the seat to turn everything on.
Here's where it gets... interesting frustrating. So the only thing that is fully on when the alarm system is engaged is the 10.5v microwave sensor ( the one that notices you are standing too close to bike) cool. But obviously 10.5v is maybe going to trip 12v relay. But maybe not. In testing. Not.
So I had grabbed a 9v relay with resistors to drop the 10.5 to 9. Then just relay it like any other. But I didn't like the idea that the relay is constantly on while the bike is off. Especially since the spy 5000 does a good enough job killing your battery if you aren't riding frequently enough. So I also grabbed a latching relay. It's pretty much a relay that just takes a pulse to trip on or off.
I can use the alarm activating to trip relay to disconnect the main power. However, I don't have anything from the alarm system that can pulse the relay to turn the main power back on. I could crack the alarm box and probably figure something on the inside. But if possible. I'd like not to. Just in case I fubar something and become sol till a new unit makes me place in a month. Anyone have any ideas for a postive pulse? Other than installing a momentary switch hidden on the bike.
The reason I want the latching is power. Once it pulses off. It takes no more energy. Where as a regular relay Sucks back .013 amps roughly (based on Google searches ) and I'm not a fan of bump starting bike. ;-)
I'm hoping there's some fellow tech guys on here.
Sexyman is offline
post #2 of 5 Old 07-17-2016, 12:21 PM
It looks to me like one relay ties red(or black/red after the connector), orange and orange/yellow(orange/red after the connector) while the other relay ties orange/green to brown. So I take it those two relays are off when you need to find a positive pulse and you want to have something on the bike that will go positive when activated with the ignition off and stay positive in normal riding. Is that the case?
post #3 of 5 Old 07-18-2016, 02:25 PM Thread Starter
Kind of? I'd like to take the positive pulse of the alarm but I'm not sure how. I can use the arming to send a pulse to latching relay to disable all power. But when I disarm alarm. The only thing that happens that I can use is microwave relay no longer gets 10.5 v.
The horn honks. But if I tied to that. Anytime someone trips it, it will flick ignition on. Which I don't want. Same problem with signal lights. Kind of frustrating.
Only thing I can think of is cracking alarm itself and find downing that pulses safely when alarm is disarmed on the board. Should be sometime. Even the signal to key set that says bike is unlocked could work?
But the bike is relayed as you stated
Sexyman is offline
post #4 of 5 Old 07-18-2016, 03:47 PM
You would need someone familiar with the alarm then. Post the model specifics.
post #5 of 5 Old 07-19-2016, 09:18 PM Thread Starter
Not too sure if this link will work.
http://cdn.instructables.com/F46/WG5...0QO.MEDIUM.jpg
Sexyman is offline
