Torque values - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
LinkBack Thread Tools
Old 10-22-2008, 08:14 PM Thread Starter
Torque values
I am reassembling the back end of an '06 DL650. I needed to apply a torch to the mounting brackets for the starboard passenger pegs. They weren't straight anymore. How bout a torque value for the four main mounting bolts for that rear subframe? I will be using some blue LocTite. I need to break down and buy a shop manual but thought I would try this post thing.
(First-timer, ya think?)
thanks, y'all.
Footnsand
footnsand is offline
Old 10-22-2008, 11:01 PM
janiceclanfield's Avatar
ITEM Nm kgf-m lb-ft
􀀒 Steering stem head nut 90 9.0 65.0
􀀓 Steering stem locknut 80 8.0 58.0
􀀔 Front fork upper clamp bolt 23 2.3 16.5
􀀕 Front fork lower clamp bolt 23 2.3 16.5
􀀖 Front axle 100 10.0 72.5
􀀗 Front axle pinch bolt 23 2.3 16.5
􀀘 Handlebar holder bolt 23 2.3 16.5
􀀙 Handlebar holder set nut 45 4.5 32.5
􀀚 Front brake master cylinder mounting bolt 10 1.0 7.0
􀀑 Front brake caliper mounting bolt 39 3.9 28.0
􀀢 Brake hose union bolt 23 2.3 16.5
􀀣 Clutch master cylinder mounting bolt 10 1.0 7.0
􀀤 Clutch hose union bolt 23 2.3 16.5
􀀥 Air bleeder valve 7.5 0.75 5.5
􀀦 Brake disc bolt (Front & Rear) 23 2.3 16.5
􀀧 Rear brake caliper mounting bolt 23 2.3 16.5
􀀨 Rear brake master cylinder mounting bolt 10 1.0 7.0
􀀩 Rear brake master cylinder rod locknut 18 1.8 13.0
􀀪 Front footrest bracket mounting bolt 26 2.6 19.0
􀀫 Swingarm pivot nut 100 10.0 72.5
􀀬 Swingarm pivot shaft locknut 90 9.0 65.0
􀀭 Rear shock absorber mounting nut
(Upper & Lower)
50 5.0 36.0
􀀮 Cusion lever mounting nut 78 7.8 56.5
􀀯 Cusion lever rod mounting nut 78 7.8 56.5
􀀰 Rear axle nut 100 10.0 72.5
􀀱 Seat rail bolt 55 5.5 40.0
janiceclanfield is offline
Old 10-22-2008, 11:17 PM
CHASSIS
ITEM Nm kgf-m lb-ft
Steering stem lock nut 80 8.0 58.0
Front fork cap bolt 23 2.3 16.5
Front fork inner rod lock nut 20 2.0 14.5
Front fork damper rod bolt 20 2.0 14.5
Handlebar clamp bolt 23 2.3 16.5
Handlebar holder nut 45 4.5 32.5
Brake disc bolt 23 2.3 16.5
Rear brake caliper sliding pin 27 2.7 19.5
Rear brake master cylinder rod lock nut 18 1.8 13.0
Rear brake pad mounting pin 17 1.7 12.5
Rear brake pad mounting pin plug 2.5 0.25 1.8
Swingarm pivot shaft 15 1.5 11.0
Swingarm pivot shaft lock nut 90 9.0 65.0
Rear shock absorber mounting nut (Upper and lower) 50 5.0 36.0
Cushion lever mounting nut (Front) 78 7.8 56.5
Cushion rod mounting nut (Upper and lower) 78 7.8 56.5
Rear sprocket nut 60 6.0 43.5
Seat rail mounting bolt 50 5.0 36.0
Cowling brace mounting bolt/nut 35 3.5
TIGHTENING TORQUE CHART
Bolt Diameter (mm) Nm kgf-m lb-ft Nm kgf-m lb-ft
4 1.5 0.15 1.0 2.3 0.23 1.5
5 3 0.3 2.0 4.5 0.45 3.0
6 5.5 0.55 4.0 10 1.0 7.0
8 13 1.3 9.5 23 2.3 16.5
10 29 2.9 21.0 50 5.0 36.0
12 45 4.5 32.5 85 8.5 61.5
14 65 6.5 47.0 135 13.5 97.5
16 105 10.5 76.0 210 21.0 152.0
18 160 16.0 115.5 240 24.0 173.5
Old 07-06-2019, 04:23 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Dam it. I was fooled by the resurrected thread for a minute. I thought Janice was back.
Try this: https://www.vstrom.info/Smf/index.ph...c,10963.0.html
notacop likes this.
richlandrick is offline
Old 07-06-2019, 09:12 PM
Yah, we miss some of the folk!
But if someone googles 'torque settings' hopefully this will pop up and make them happy!
Old 07-07-2019, 08:01 AM
Dark Angel's Avatar
Originally Posted by RLBranson View Post
right off the bat the rear axle nut and rear sprocket nut are bad info.
Care to elaborate? The figures in the first post align with those in the linked thread.
Dark Angel is online now
Old 07-07-2019, 09:49 AM
Grey Wolf suggested the 72 ftlb was too high. Better at 56 or something like that.
Old 07-07-2019, 10:42 AM
Charlie1982's Avatar
The lower number was suggested/recommended along with using antii-sieze on the axle threads.
Charlie1982 is offline
Old 07-07-2019, 02:45 PM
Dark Angel's Avatar
This is what I remember as well.
Old 07-07-2019, 03:46 PM
Stalky Tracker's Avatar
Yep, Greywolf recommended 58 ft lb and anti-seize on the rear axle nut. Anti-seize to prevent galling and 58 due to the use of a lubricant (anti-seize) which lowers the 72 setting to 80% or 58, if I remember correctly.
Been using both since '06.
notacop and Cryoman like this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
