Torque values - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #11 of 15 Old 07-07-2019, 04:01 PM
Dark Angel's Avatar
Originally Posted by Stalky Tracker View Post
Yep, Greywolf recommended 58 ft lb and anti-seize on the rear axle nut. Anti-seize to prevent galling and 58 due to the use of a lubricant (anti-seize) which lowers the setting 80%, if I remember correctly.
Been using both since '06.
TO 80%, yes. Just so nobody thinks they should lower it BY 80%.
Dark Angel is online now
post #12 of 15 Old 07-07-2019, 04:09 PM
Stalky Tracker's Avatar
Correct, thanks.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #13 of 15 Old 07-07-2019, 04:25 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
If you are referring to the chart I linked, yes it is older than Greywolf's advice. I believe the numbers came from Suzuki Service manuals.
richlandrick is offline
post #14 of 15 Old 07-07-2019, 04:48 PM
Dark Angel's Avatar
From memory that was based on the use of anti-seize. The original specs are based on the threads being clean and dry.
post #15 of 15 Old 07-07-2019, 05:31 PM
I set mine at 58 dry and with a clip through the nut and axle hole, I've experienced no problems. It's a good idea to grease the axle though. One of my beemers kinda rusted in place and it took a couple whacks on the axle to knock it loose.
