Can you make ABS switchable? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-25-2013, 10:37 PM Thread Starter
Hi there,
My understanding is that the ABS module searches for a power supply on start up then when the bike goes over 5 km/h the ABS error light goes out.
Is there a way to use this to make the ABS switchable?
Might be too many issues, but would be handy in certain situations.
Socrates_101 is offline
post #2 of 6 Old 03-26-2013, 12:50 AM
tread55's Avatar
Originally Posted by Socrates_101 View Post
Hi there,
I believe this will help do what you are looking for. VStrom. I think I've also read some posts about pulling the fuse but I think you needed to pat your stomach and rub your head to get it back on or something . Unfortunately I have to suggest trying to search for it on the forums. I'm not a fan of people answering questions with 'use the search function' but in this case, give it a try and you should find some posts about switching it on and off. I hope I was of some assistance to you. Please follow up with any info you find or how you plan to go about doing it. It is something I have thought about doing, just in case.
Cheers,
Brent
tread55 is offline
post #3 of 6 Old 03-26-2013, 07:03 AM
Turning it off is easy. To turn it back on, you have to turn the bike off and back on.
Pete
PeteW is offline
post #4 of 6 Old 03-26-2013, 10:07 PM
Check with Eastern Beaver, they should have what you need along with alot of other goodies for the Strom.
coral_snake is offline
post #5 of 6 Old 04-06-2013, 06:19 AM
I've done the abs mod , got the wire and switch through EB and works grate . You can switch it off at eny time but to switch it back on you have to turn off the ignition to reset it ! But that's no probs
Calman is offline
post #6 of 6 Old 04-06-2013, 06:28 AM
Nova Scotia Strommer's Avatar
Check out this link:Proper ABS on/off switch
You can swich on the fly with this mod.
09 DL650 ABS ORANGE "Form over function at a superior price"
09 DR650 "Hooliganizer"
03 TW200 "No Roads....No Problem"
02 TW200 "Redneck Edition"
Nova Scotia Strommer is offline
