oil pressure sending unit slow leak - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-25-2013, 12:40 PM Thread Starter
So on my K2, I have a slow oil leak that appears to be coming from the oil pressure sending unit:
2002 Suzuki V-Strom 1000 DL1000 Parts, 2002 Suzuki V-Strom 1000 DL1000 OEM Parts - BikeBandit.com
part #25
Stupid question - is there an Oring on this guy? a gasket? pipe/tubing thread? RTV? Anybody care to share? The unit itself seems OK, just need to stop the harley imitation, as it's making my feelings sad.
charlescranfill is offline
post #2 of 4 Old 03-25-2013, 12:56 PM
There is no O-ring or gasket on the fiche. It's probably a tapered pipe thread. I'd try taking it off and adding Teflon tape or pipe dope.
post #3 of 4 Old 03-25-2013, 12:57 PM Thread Starter
sweet, that's the answer I was hoping for. Thanks a ton!
post #4 of 4 Old 03-30-2013, 09:19 AM Thread Starter
just confirming, no O ring. I pulled it, added some teflon tape, popped it right back in. It was full of oil under the boot/cover, so I feel pretty good that was the source of the leak.
