New to bike and forum, spark plugs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-18-2013, 12:30 AM Thread Starter
Clone's Avatar
Hi, new to the bike DL650, and the forum.:mod_sad:
Now I searched, I did, really! But cannot find a "How to" on changing the plugs. From the manual it looks like I pretty much have to dismantle half the bike to do it.
Was going to change plugs, air filter, coolant, and oil while it is all apart, just hoping there is an easier way to change the plugs without taking the rad off.
Thanks
Clone is offline
post #2 of 9 Old 02-18-2013, 07:20 AM
CanadianFZ6's Avatar
I never had to take the rad off to change plugs... What model of Wee are we talking? the pre 2007 (I think) has 2 plugs, but the '07+ has 4...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #3 of 9 Old 02-18-2013, 01:02 PM Thread Starter
Clone's Avatar
Re: New to bike and forum, spark plugs?
Hello it is a 2007abs. I swear it said to remove the rad for access to the front plug
Sent from my Nexus 7 using Motorcycle.com Free App
Clone is offline
post #4 of 9 Old 02-18-2013, 01:10 PM
Using the toolkit spark plug wrench, the idea is to remove the lower radiator bolt and pivot the radiator away for access. Care needs to be taken not to bend fins or scrape hands. I only changed plugs once at the same time I did the valve clearance inspection. Removing the radiator is to way to go for doing that and access was easy. The stock plugs are good for over 20,000 miles. Replace them with iridiums and probably never change the plugs again. I really don't see a purpose in replacing plugs outside of valve clearance inspection times.
post #5 of 9 Old 02-18-2013, 05:23 PM
If your '07 hasn't had the coolant renewed (or you don't know when) do that as part of the job.
You'll learn to cluster the jobs so you get the most done for the time you spend removing the plastic and the tank. Valve lash check, plugs, air filter, coolant, check the hoses for tightness, give everything a close look-over.
The iridium plugs don't work better than new copper plugs, but they work like new for a very long time.
post #6 of 9 Old 02-18-2013, 06:11 PM
Stalky Tracker's Avatar
I'm with Greywolf and PTrider. I changed my plugs to iridiums at valve check time, plus replaced the air cleaner and coolant then too. I drained the coolant and completely removed the radiator and it made everything a lot easier.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 9 Old 02-18-2013, 10:01 PM Thread Starter
Clone's Avatar
Yup, was going to do a lot of the service when I did this. The previous owner said the dealer checked the valves at 14,000, that was 3 years ago. So now at 20, was going to change the coolant and drop in new plugs so that I could ignore it for a few years.
Clone is offline
post #8 of 9 Old 06-07-2013, 08:38 PM
I did the coolant and plugs over the winter for the first time. Not difficult if you loosen the radiator although you will skin some knuckles on the plugs.
sjsred323i is offline
post #9 of 9 Old 06-08-2013, 12:34 AM
Scott E. Bonds's Avatar
Its not that bad. Loosen the radiator lower bolts and pivot it out as far as you feel safe, then wedge something that will not hurt your rad in the open space to hold it.
Iridiums are definitely the way to go for several reasons..longevity being the main one.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
