Crash bar bolts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 02-03-2013, 09:07 PM Thread Starter
DLleona's Avatar
Crash bar bolts
Ok, so I want to loosen the mounting bolts on my 2011 dl650 Givi crash bars (on both sides of the frame) so I can pull out the center pin and hit it with some rtv to get rid of that annoying vibration. My question is are these actually the engine mounting bolts? Do I need to Block up the engine somehow when loosening these bolts?
DLleona is offline
post #2 of 14 Old 02-03-2013, 10:09 PM
The engine is sufficiently supported by other fasteners. You don't need to block it up. If you use a torque wrench, the bolts need 16.5lb-ft, not the 25.5 in the service manual.
post #3 of 14 Old 02-03-2013, 10:57 PM Thread Starter
DLleona's Avatar
Crash bar bolts
Thanks Greywolf, maybe Ill go do some more shopping too.
DLleona is offline
post #4 of 14 Old 03-17-2013, 05:11 PM
The SW Moteck instructions say to use the service manual torque unless there is no instruction then use 16.5 ft / lb. Which is it? I did mine to 25.5 ft/lb per the service manual.
sjsred323i is offline
post #5 of 14 Old 03-17-2013, 05:59 PM
teevee's Avatar
or get some alt-rider bars and forget about having to deal with vibration. sure they're expensive. but worth it.
and no, i don't work for them...
'08 DR650, '07 DL1000
teevee is offline
post #6 of 14 Old 03-17-2013, 06:35 PM
The service manual is wrong. 16.5lb-ft is correct.
post #7 of 14 Old 03-17-2013, 07:00 PM
Re-torqued to 16.5. Thanks
post #8 of 14 Old 05-15-2013, 11:00 PM
I cannot for the life of me remove the small bolts needed to install the SW Motech crash bars. Has anyone else had this problem? I am afraid of stripping the bolts (allen wrench). If anyone has any tips or tricks, I would appreciate it. Thanks.
2009 Wee-Strom
DCOURTS1984 is offline
post #9 of 14 Old 05-16-2013, 12:38 AM
Stick a soldering iron in the hex for a minute to heat the thread locker. If no joy, try another minute, etc..
post #10 of 14 Old 05-16-2013, 02:02 AM
Stromtrooper.com Sponsor
Satch's Avatar
Go buy a set of metric hex bit sockets.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
