removing stubborn bar end. . . - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 10-24-2012, 08:23 AM Thread Starter
I was going to remove my bar end to install a throttle-lock. I loosened the nut (not all the way-I learned my lesson), but it refuses to budge. It seems "frozen".
Any suggestions would be appreciated.
thx
barry
sd2ftl is offline
post #2 of 4 Old 10-24-2012, 10:49 AM
henerythe8th's Avatar
Push in on the screw. Then pull on the bar end and rotate around in a circle as you keep pulling.
the rubber piece that expands is stuck to the inside of the bar, which is good, until you want to remove it...
2011 MG Stelvio
henerythe8th is offline
post #3 of 4 Old 10-25-2012, 12:53 PM Thread Starter
thx. . .removed stuck bar end--just like you said, no prob
sd2ftl is offline
post #4 of 4 Old 10-30-2012, 04:36 PM
When you learned your lesson on the first one were you able to find ne hardware? Seems like I am having a lot of learnings.
Surf-or-Ski
2011 DL650 ABS
1981 Honda CX500c
Surf or Ski is offline
