oil drip - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-10-2012, 01:06 PM Thread Starter
BillZ's Avatar
oil drip
Changed oil over the weekend and now I have a slow drip. I rode to work today and had one drop of oil on the drain plug when I arrived after 26 miles commute. I tightened the plug but I am freaked out about those posting about stripped oil pan. I don't have a torque wrench and am not sure that I'd use it if I did, based on reports of problems with over tightening. I did not change the drain plug washer, but I consulted the dealer here and they don't always change the washer either.
I know this thread sounds rediculous because most would advise to change the washer and use the torque wrench, so I really don't know what to say, except I'll put the wrench on the plug again, just to make sure it's snugged up.
"Not all those who wander are lost." J.R.R. Tolkien
DL650AL
LIMNCS #51
Shiro Nakama Shichi #007 :beatnik:
BillZ is offline
post #2 of 4 Old 09-10-2012, 01:32 PM
Could just be oil that worked it's way down from the threads when you tightend it, wipe it off and just keep and eye on it for now. I think you will be fine since you just barely snugged up the bolt, just always be sure to use an open end wrench and not a socket. For the record, I almost never changed crush washers on every bike I have owned.
post #3 of 4 Old 09-10-2012, 02:28 PM
568v8's Avatar
oil leak
Apparently crush washers work better than flat washers and should be replaced each time. Ya, they can be a pain to get off the drain plug.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #4 of 4 Old 09-10-2012, 03:10 PM
Sometimes the washer falls off the plug and is still in the oil when you put the plug back in.
That's a bother cus you loose a lot of oil even if you are fast doing the swap-o change-o.
I've had the washer last through years worth of changes even at 3 K intervals.
