Chain Adjustment Video - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Wmason1961
post #1 of 7 Old 08-21-2012, 09:00 AM Thread Starter
JayS's Avatar
Just adding a quick drive chain adjustment video for 2012 vstrom 650.
Chain Adjust - YouTube
~~~>Jay<~~~
JayS is offline
post #2 of 7 Old 08-25-2012, 04:28 AM
Nirvashone's Avatar
Was hoping for a walk through
Sent from my SPH-D710 using Motorcycle.com Free App
Nirvashone is offline
post #3 of 7 Old 09-13-2012, 05:57 PM
ked
thanks for the video!
ked
if a man speaks, and there isn't a woman around to hear him, is he still wrong?:confused1:
ked is offline
post #4 of 7 Old 09-13-2012, 06:38 PM
Wmason1961's Avatar
The owners manual clearly states to adjust the chain using the side stand. I don't know how much difference it makes to have the bikes weight on the wheels instead of having the wheel hanging, but I assume that Suzuki engineers had a reason for stating it in the owners manual.
jboban likes this.
Wmason1961 is offline
post #5 of 7 Old 09-14-2012, 01:22 PM
The book spec is for the bike on the side stand. You could set it to spec on the side stand, then put the bike up on the centerstand and find the resulting measurement for future use on the centerstand.
On the pre-2012 bikes the marks on the swingarm are not accurate enough for chain alignment--they're a starting point, then sight down the chain to be sure it is running straight off the sprocket. I don't know if the L2 bike has accurate marks, but I wouldn't trust them without a careful look.
Little or no need to clean the chain, but it does need lube for longest chain life. Lube every other tank of gas is a good rule of thumb, and lube every tank when running in the wet or in abrasive grit. A simple wipe with a dry cloth is OK for getting dirt off--I don't use kerosene or anything else to clean, and I don't use a goopy lube. As always, never ever run the engine while cleaning or lubing the chain--fingers have been cut off doing this.
post #6 of 7 Old 09-15-2012, 01:05 PM
Scarlett Harlot's Avatar
Hands down, it is much easier to adjust my chain with the bike on the side stand. The adjusters move better and there is a lot less of this fat man flopping around on the garage floor to measure the chain freeplay. I have also found that the marks on my swingarms are pretty much spot on for reference points.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups.” ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #7 of 7 Old 05-19-2016, 03:07 PM
That's funny......took you more like 2 hours to adjust your chain from what I have seen. Of course you are a shaft drive guy now, you have other things to worry about.
