Crankcase Bolt Torque - I don't want to mess up - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-12-2012, 12:13 AM Thread Starter
I want to remove the brackets that formerly held the Vee plastic lower guard. I just want to de-clutter. They are held by crankcase bolts. The service manual recommends 11 Nm for M:6 and 26 Nm for M:8 crankcase bolts. I expect these bolts are M:6 but I will measure the diameter after removing one. Before I mess anything up, does anyone have any input?
07 DL1000, all farkled up
mountainmeterman is offline
post #2 of 4 Old 08-12-2012, 12:32 AM
henerythe8th's Avatar
You don't really need to use a torque wrench for that job.
You need to use a 1/4 or 3/8 drive ratchet and make them snug tight.
2011 MG Stelvio
henerythe8th is offline
post #3 of 4 Old 08-12-2012, 01:26 AM
They are M6x1.0. If you use a torque wrench, keep your head in the game. A badly calibrated, wrongly set or too large a capacity torque wrench can wreak havoc with small bolts. 84 inch pounds on my little 200in-lb torque wrench is what I use on 6mm shank bolts on critical areas like camshaft pillow blocks.
post #4 of 4 Old 08-12-2012, 01:34 AM Thread Starter
Thanks guys. I do have a low range torque wrench.
