Advice Needed: Patching hole in plastic - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 06-29-2012, 11:41 AM Thread Starter
Question Advice Needed: Patching hole in plastic
I bottomed out on my bike recently, and now there's a hole in the tray under the seat on my VStrom. Obviously, I need to get a shock rebuild done and then replace the tray under the seat. This is what I plan to do when time/ funds allow, but for now I would like to patch this hole so water doesn't get in. Does anyone have any ideas?
I heard someone online got some plastic shavings of ABS plastic, let them sit in MEK for a day and it turned them into a goo that he could spread over his holes, let dry and paint. Has anyone heard of this before? Can anyone confirm if the tray under the seat is ABS plastic (how do I check?)?
Anyone have a tray or rear shock for a DL1000K7 they want to part with for reasonable price? Old shock is ok as I'll send it in to Sasquatch or someone for a rebuild.
Any other ideas. Doesn't have to look pretty, just would like the hole gone. Here's some pics. About the size of a quarter.
From the top down:
From the bottom:
"The first five days after the weekend are always the hardest."[INDENT]-- My wife[/INDENT]
WiredDriver is offline
post #2 of 13 Old 06-29-2012, 04:27 PM
I had a friend that made a putty/paste of ABS and other plastics to repair his poor skimmer. It can work but might take a while to get the consistency you want. You'll ned dto clean the parent material for a good bond too.
Or you could cut a piece of plastic and pop rivet a band-aid over the hole a use silicon to seal it off.
notacop is online now
post #3 of 13 Old 06-29-2012, 05:28 PM Thread Starter
Yeah, I've thought about band-aiding it with a piece of aluminum or something. How did your friend make this putty?
I'm just worried that by riveting or screwing down anything, if I bottom out again before I can upgrade the shock, the screws might go into the tire rather than just rub if I can put on a compound like a putty. Then I would be in even more trouble.
post #4 of 13 Old 06-29-2012, 06:49 PM
My bike is down with an electrical issue at the company garage so I can't check; but if it's the same material as the belly cowl I believe it's HDPE and ABS cement won't work.
1.3G is offline
post #5 of 13 Old 06-29-2012, 07:36 PM
It looks like a crack has formed on one side. It should be stop-drilled first to prevent the spreading of the crack. Just drill a small hole at the end of the crack. I would use fiberglass cloth with epoxy. Just rough up the plastic where you will be bonding to.
2009 DL650
Stromburger is offline
post #6 of 13 Old 06-30-2012, 06:24 PM
He took a few bits of the plastic and added the solvent for that plastic and let it marinate. You'll have to experiment.
My friend is now very dead and I can't ask how he did it no more.
post #7 of 13 Old 07-01-2012, 11:54 AM
Stalky Tracker's Avatar
No experience here, but how about one of the JB Weld products? If they won't cover the hole, maybe a small piece of plastic or aluminum JB Weld'd over the hole?
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #8 of 13 Old 07-10-2012, 08:52 PM
If you're just looking to keep out moisture until a permanent fix is made, why not duct tape? Use aluminum tape - as used for actual ductwork - if you have something against the non-metallic variety. - Red Green.
Maybe a small sheet of Kydex, heated over a form for proper shape, and siliconed in place?
skysensor is offline
post #9 of 13 Old 07-11-2012, 11:11 AM Thread Starter
Thanks for the suggestions guys!!
I tried the cheapest route first, Gorilla tape on both sides. We'll see how she holds up.
post #10 of 13 Old 07-11-2012, 03:59 PM
Failed pre load adjuster
richw is offline
