Front sprocket replacement - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 17 Old 11-17-2013, 07:15 PM
I'm having issues re-installing the chain on the slightly larger 16t front sprocket. Any tricks out there?
2013 V-Strom 650 Adventure (commuting machine)
2012 Kymco Like 200i (for fun):biggrinjester:
JPilot is offline
post #12 of 17 Old 11-17-2013, 07:28 PM
HotPockets's Avatar
Did you loosen the chain tensioner?
'07 Yamaha Vstar 650 (sold)
'09 Honda CBR600RR (sold)
'12 WEEEEEEEstrom :biggrinjester:
'13 Yamaha FZ8
HotPockets is offline
post #13 of 17 Old 11-17-2013, 07:31 PM
Yes, chain slack isn't an issue, just the clearance in front of the sprocket
JPilot is offline
post #14 of 17 Old 11-17-2013, 08:00 PM
Did you try putting the chain on the sprocket before installing the sprocket, or putting the chain in the area before the sprocket?
post #15 of 17 Old 11-17-2013, 08:36 PM
kiwi_outdoors's Avatar
be careful beacause
Originally Posted by JPilot View Post
This nut's proving to be a real bastard. Can't get it off with my breaker bar. Socket keeps popping off. I'm thinking of going and getting a socket with less points and/or an impact wrench. The excessive torque and gobs of orange thread lock are proving to be my nemesis!
if you make up a breaker bar from pipes, you may "slip" and scratch up the magneto cover - as I did
my sprocket nut on the ABS bike took a lot of effort to break loose. On my non-ABS bike it was no big deal.
kiwi_outdoors is offline
post #16 of 17 Old 11-17-2013, 08:51 PM
I did attempt to put the chain on the sprocket first but couldn't get it past the clutch assembly/housing, then I tried putting the sprocket on first then the chain but the gap was too small
JPilot is offline
post #17 of 17 Old 11-17-2013, 08:52 PM
Finally made a PVC breaker bar so I didn't hurt myself (or more importantly the bike). Success!
JPilot is offline
