coolant maintenance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-06-2012, 01:33 PM Thread Starter
toronto_nic's Avatar
coolant maintenance
i'm looking to do my first coolant maintenance but looking for the proper procedure, maybe with some pictures?
2008 Vstrom DL 1000
toronto_nic is offline
post #2 of 8 Old 06-06-2012, 02:10 PM
I viewed you tube under coolant change on a motorcycle. Pretty simple to do on my dl 08. Just followed the video there really. I used a very long/skinny funnel to re fill the bottle/radiator. Had to tap the side cover area and rock the bike a little to make sure I got the air out. Use a rubber mallet for this with a cloth over the side cover to not mark the surface. Mix your coolant before or use pre mixed. You warm up the bike a little, rock it, stop it. Did that 8 times and all bubbles left the system. It's been at two, and occasionally 3 bars in hard traffic.
2008 DL1000 - Two Bros cans, ProTaper Bar, Oxford Grips, PC111, Givi crash bars, MCA screen, bark busters, rad & bash guards.
1977 BMW R100S - SOLD
1984 BMW R80RT - Sold
1984 DR185 - Retired
timr is offline
post #3 of 8 Old 06-06-2012, 05:46 PM
Azrael's Avatar
Be sure to "burp" the air out of the radiator hose going to the water pump. This is done by squeezing the hose repeatedly until it fills up with fluid.
just because you are a character
doesn't mean you have character
Azrael is offline
post #4 of 8 Old 06-06-2012, 07:18 PM
SnoPro753's Avatar
Is there a certain specification the replacement coolant needs to meet?
08 DL650 Flat Black
(Formerly: [URL="https://www.stromtrooper.com/stromtroopers/73004-changed-my-username-windharvester-snopro753-pics-inside.html#post788292"]WindHarvester[/URL])
SnoPro753 is offline
post #5 of 8 Old 06-06-2012, 08:37 PM
These engines seem to be tolerant of just about any antifreeze. my preference is for any motorcycle specific antifreeze, or Zerex Asian Engine antifreeze, or any Japanese car antifreeze...Honda, Toyoya, etc. The Zerex and some of the car products have corrosion inhibitors good for five years. most of the motorcycle juice is good for two years.
draining the coolant reservoir can be a bit of work. that is one of the jobs to cluster with others that need the gas tank removed.
post #6 of 8 Old 06-06-2012, 08:54 PM
NWArkie's Avatar
Yes! Do this when you are changing spark plugs, checking your valve clearance, and changing your air filter. Checking valve clearance will require you to drain the coolant and remove the radiator anyway!
NWArkie is offline
post #7 of 8 Old 08-03-2012, 04:48 PM
biker128pedal's Avatar
Valves can be checked without removing the radiator. I would not want to change shims though. I bought Suzuki fluid. Note the manual fill amount in quarts is wrong. You just need one quart. A shop will look it up and sell you two. I have an extra for next time.
The new stuff is blue. An '09 will take either.
Vstrom 650 ABS
'09 DR650
'07 Vulcan 900 LT
biker128pedal is offline
post #8 of 8 Old 08-03-2012, 05:16 PM
1 quart is not enough. There are errors in the manual but not that. Discrepencies in coolant capacities in the service manual
